Engine compartment sticker replacement
The factory sticker for my engine compartment (the one that contains the info on the A/C charge) started to peel off, so I decided to just remove it altogether. Does anyone know where I can get a replacement that will properly adhere to the plastic panel? I need to keep it stock.
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
You could try http://www.performancepartsinc.com/misc.htm
Quote from close to the bottom of the page: "We carry virtually all the hard-to-find original equipment interior, exterior and engine compartment "detailing" decals for 1979-08 Mustangs to complete that perfect restoration! We also have most original sales literature, too!"
Before you install a new sticker only to most likley have the same thing happne try these steps prior to installing it.
Clean the surface with Denatured Alcohol. Then get some 3M adhesion promoter that come in a little foil type pack and apply it and let it dry prior to laying the sticker down. Rest assured the sticker will not come off affter this has been done.
This is the stuff i am refering to. You should be able to get it at any Body Shop Supply store.
http://www.amazon.com/3M-Adhesion-Pr.../dp/B00063VRXU
sarnold58
6/9/19 02:22 PM
MrSylphie
8/18/15 08:40 PM
