Door ajar issue.....help.
OK - when driving, the door ajar light and associated beep keeps on recurring. Sometimes it'll beep once, sometimes about 10 times in a row, and sometimes 2-3 randomly, over and over and over. The map lights come on with the beeps ONLY when stopped. This has been going on for about a week. (annoying is an understatement).
I did try carb cleaner on the switch to see if the sensor is stuck - no luck.
How difficult is it going to be if I have to replace the entire lock mechanism & sensor? OR - is there a better solution.
I searched all over the boards for someone else with this issue and didn't find any threads.
Thanks in advance........
legacy Tms Member
mine does that when trunks ajar I programmed the same remotes for both cars, and the van, but she uses the trunk button on hers and about once a week in the summer, mine will have the trunklid bouncing ding-ding-ding...
funny- first time it happened was a day after I'd left my windows down and it rained overnight, I thought for sure it shorted some stuff out, but about halfway to work i noticed it was when i hit a bump, and happened to see the spoiler hop in the mirror a bit- doh!
its the drivers door for sure, because sometimes, I can open/close it while rolling and "reset" it - which rarely lasts more than a few minutes.
I don't think the auto up/down feature on the door is the culprit, it seems to operate normally when open and closed - but once in a while it will go up/down while the door is closed when the door ajar light and beep occurs.
The Analog Admin!
Received 3,157 Likes
There you go! Thanks in advance if I ever need one.
Thanks KC - I was actually hoping you'd chime in here somewhere.
Red pony - no luck - warranty was expired about 15K miles ago.
I'll go find that part and give it shot. It should cure the issue. Again - thanks guys.
Having same issue
I know this is an old post, but was hoping to see if you determined what was causing this. I am having the same issue with my '07 convertible. Door ajar comes on and drivers side window doesn't work nor does the wipers. Going over bumps seem to turn the light on and off. Happens normally when cold. Replaced the door latch sensor and sprayed the latch with WD40. Seems to reduce it from happening. Not sure what the door ajar and wipers have in common. When everything is working as it should and I open the door, the drivers side window operates as does the wipers. No moisture near the main junction box and all contacts on it look clean.
My 2006 GT is doing the same thing. I changed the switch sensor and I'm still having the same problem. Any other ideas what it could be?
