DIY lube/oil change
Old May 17, 2006 | 10:16 AM
Scarpi's Avatar
DIY lube/oil change
I am tired of getting the oil overfilled by dealers and other garages with each oil change on my 05 GT. I've done oil changes myself on other cars I've had using ramps to get under the car. The only thing I'm not aware of is how to do a lube job. What equipment do I need to buy and what needs to be lubed on an 05 GT? Can someone tell me where the lube points are? Are they obvious? As you can see, I'm not a mechanic so any info on this is truly appreciated. Also, what do you do with the old oil?
Thanks a bunch
Don
Old May 17, 2006 | 11:21 AM
FRITZ's Avatar
There are no lube points on our cars.
Old May 17, 2006 | 11:59 AM
05YellowGT's Avatar
As far as the old oil , most car parts stores will take it ...
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
