Difficulty of changing pads/rotors on this car?
I've done it before on other cars and it helps that they're hubless rotors. How difficult is it on these cars? Any special stuff to do? Also does anyone know the bolt size(s) on the caliper for removal?
You don't even need the special tool, I normally just use a large c-clamp and that does the trick for me. Leave the old pads on, open the c-clamp all the way, slide on and compress the pad all the way down, removed the old and put on the new. Its real easy bro.
Then don't EVER come near one of my cars..
That is a sure fire way to break the rear calipers.. C clamp is what you use on the fronts but not on the rear.You have to turn the rear caliper to compress it..
You WILL break the rear caliper if you try that. They have to be screwed in. The rear pistons are threaded, they just don't slide in and out.
Not on the rears, if you do manage to get them in which is not likely you'll be buying new calipers to go along with your new pads(and some brake fluid too).
You can also do the rears with a pair of needle nose pliers. I've had good luck doing it that way. Just hold the pliers open and put the nose ends in the slots of the piston, then turn. It's not that hard to do. I've done it 4 times now (changing back and forth between track and street pads).
If you have done brakes before don't be afraid to do these they are easy. If you have any Autozone stores in your area they loan the tool for free. Turning the piston in is no big deal, its no more difficult than using a c-clamp on the traditional style.
? Does it rotate as it pushes the pad under braking ?
Changing brakes on this car is a snap! Out of all my cars, this is the one I have no issues with doing brakes. The rears, with the use of a tool, are simple. I didn't know about the Nissan thing, so I bought a "universal" and ground off the tabs that didn't work with the Mustang. So I now have a "universal -" tool. Tool was $7 at AutoZone. With a socket wrench, 2 beers, and 1 1/2 hours, you will have saved yourself some money and been under your car long enough to see the springs aren't hard to change either!
roushcollection
Jul 28, 2015 02:08 PM
