Different types of Hood Pins?
Old 12/12/07, 06:18 PM
Pwny's Avatar
Are pins difficult to install?
Old 12/13/07, 07:04 AM
martin fink's Avatar
Took about 2HR to install have some clay to place under hood to find center of pin to drill.The hard part is a 3/4 drill I started with a small bit and went to a 1/2 " then used a taper drill that has graduated sizes.
Old 12/14/07, 10:54 AM
gofarlow's Avatar
I did not realize the shelby pins come in black. Another thing to add to the buy list.
Old 12/14/07, 11:49 AM
RFLgtcs's Avatar
has anyone used the steeda hood pins?
also, my friend has a black fiberglass aftermarket hood w/ pins and he has had his hood repainted about 7 times because of the pins causing the hood to crack around that area.
i am thinknig of getting the steeda full cowl hood and steeda hood pins, will i have the same problem?
Old 12/14/07, 08:07 PM
Boltzman's Avatar
I just bought Steeda's but my hood is not gettin done till Jan 14. I'll post up then.
Old 12/15/07, 08:58 AM
Fords4Ever's Avatar
Originally Posted by spyder7724
I have aerocatch hood pins.(on my car and on my website) they are flush mount design that has no lanyards and are totally made of paintable composite material so there's nothing to scratch or rust.
the install isn't too hard but it definitely is something that should be done by one who is comfortable with a drill and saw.
here's a pic installed:
For some reason I cannot see your attached pics. Do you have any pics with somewhat of a closeup installed?
Old 12/16/07, 06:54 PM
spyder7724's Avatar
i'll try a different one. PM me with your email address and i'll send some better quality photos.
it won't load any into the thread so I'll have to send you some from my email.
Old 12/16/07, 07:18 PM
turbo05gt's Avatar
Im waiting for the pins on the gt500 KR to come out.
Old 12/17/07, 07:29 AM
Boltzman's Avatar
Good luck...
Old 12/19/07, 04:43 PM
mikeelia's Avatar
Originally Posted by 05YellowGT
I got a set of pins for a 71 Mach1 and had them custom installed. It was expensive , but I like these so much better than the FRPP ones I had before ...
Love those tri-locks. Doesn't "Fang" [I think that's the name of the place] sell these for the 2005-up cars? Pricey when I checked last, though.
Mike E
Old 12/19/07, 06:15 PM
turbo05gt's Avatar
Originally Posted by Boltzman
Good luck...
Soon my friend soon. Ill post pics.
Old 12/19/07, 06:23 PM
Pwny's Avatar
I like the Shelby ones the most.
Old 12/20/07, 07:22 AM
Jager's Avatar
Mike E
I found a couple of sources...
http://www.metropartsmarket.com/cata...rts-c22s3.html
http://www.tntmustangconnection.com/cat16.shtml
and the other one...(click on image for animation)
Old 1/24/08, 09:43 PM
cop on my back's Avatar
Thinking I need hood pins, which ones?
The more I see pictures of the 05+ Mustang with hood pins I think I need them to. I have some concerns / questions however:
-What if the tethers rub the hood at highway speeds and scratch / remove paint?
-Drilling holes in the hood, just cover bare metal edges with touch up paint?
-Stainless, chrome (corrosion resistant)
-Place to buy?
-What will they look like after 5+ years?
I do want the tethers, I think they look better.
Old 1/24/08, 10:10 PM
GRAYPNY's Avatar
Lots of different opinions on hood pins but I went with the Ford Racing pins because I like the 'old school' look. I have had zero issues with the lanyards scratching the paint. I have them pretty well tucked so there isn't alot of slop. I do have some scratches on the plates but they are easily replaced and when the pins are in you can't see them. I also filled the gap in the layers of the hood with some liquid metal stuff to keep the water out.
Attached Thumbnails Different types of Hood Pins?-picture-188-small-.jpg   Different types of Hood Pins?-picture-184-small-.jpg   Different types of Hood Pins?-picture-019.jpg
Old 1/25/08, 08:48 AM
hauss1's Avatar
I got the Shelby hood pins but I have not installed them yet. I actually went w/ those b/c they 5 inches and are supposed to not require raising or modification to penetrate the hood. But once again I have not installed them.
Old 1/26/08, 05:17 PM
omendez's Avatar
I just put mine in, I bought them at Auto Zone for 9 bucks, I removed the hood bumps, and drilled from the underside of the support so I could fit a 3/4 socket, I got the location of a saleen I saw.
Old 1/26/08, 05:29 PM
omendez's Avatar
sorry about the first post, hope this works better
Old 1/26/08, 05:44 PM
Any with the hood closed? I have seen a few in that location, I like that spot as it puts them farther to the outside. I have black stripes, so I don't want them close to the center.
Old 1/26/08, 05:58 PM
  #40
omendez's Avatar
the only one i have at the moment is this one, but ill be taking some new pics when i get it back from the shop.
Quick Reply: Different types of Hood Pins?
