Console cracking noises when shifting
Old Feb 19, 2005 | 04:53 PM
Preacher's Avatar
I hear an annoying noise when shifting especially in third fifth gear. I think the cracking noise come from where the leather trimming of the shifter attach to the console. It doesn't feel smooth when I shift and it's getting on my nerves. Anyone else got that?
Old Feb 19, 2005 | 06:04 PM
drizztbob's Avatar
The noise is coming from the leather wrap inside the car?
Old Feb 19, 2005 | 06:19 PM
Preacher's Avatar
Yes, I think. Or the console... It's not the transmission... Its like a "TICK! TICK!" if I shift strongly. Just feel cheap...
Old Feb 19, 2005 | 06:25 PM
z71mudder199's Avatar
The only noise i hear when shifting is when i shift from first to second... All i hear is a nice little bark of the tires
Old Feb 19, 2005 | 06:32 PM
38special's Avatar
It could be your keys jangling. Or the false bottom of the cup holder moving about. When you say "tic tic," that is what I would look for.
My arms rest on the console as well. Could the lid of the unit be moving?
Old Feb 19, 2005 | 06:47 PM
PalaceOfStangs1's Avatar
I think I know what he is talking about. The leather wrap around the shifter kind of "pops" when it shifts right after startup when it's cold outside. It's not THAT big of a deal, I don't think. I don't think it does it anymore though. Not sure if that's what you're hearing.
Old Feb 19, 2005 | 07:00 PM
Preacher's Avatar
Could be it Chad. I think it does it more when it's cold outside. I think it's coming from the bulge at the base of the leather wrap at the place it ties up to the console. If I push there I can hear the sound. Definitely no big deal but I tought maybe something was cracked down there on my car...
Old Feb 19, 2005 | 07:24 PM
I would think it's more cosmetic than anything mechanical. Maybe someone else that has experience with this sort of thing could chime in?
Old Feb 19, 2005 | 07:55 PM
outdoorstom's Avatar
Have you made any enemies lately? It's not a bomb, is it?
Old Feb 19, 2005 | 11:40 PM
Preacher's Avatar
hehe... I'm may have some enemies but even them wouldn't dare put a bomb in such a nice car!
Old Feb 20, 2005 | 08:02 AM
drizztbob's Avatar
Have you tried using a leather cleaner on it? This may loosen the material up or even create a cheap lube for it...
Old Feb 20, 2005 | 12:00 PM
Preacher's Avatar
Could be an idea Bob...
Old Feb 21, 2005 | 10:23 AM
2Slack's Avatar
I hear the same noise. I find that pushing down on the rectangle trim helps. It is caused by the trim vibrating.
Old Feb 21, 2005 | 01:07 PM
Preacher's Avatar
That's exactly what I mean 2Slack. The problem is in the rectangle trim..
Old Feb 21, 2005 | 02:58 PM
Dan's Avatar
Dan
Do You Remember Me?
I have a crackling noise coming from the back of the dash. Haven't really tried to figure out what is caused it though. Sounds something like bubble wrap popping or something expanding due to heat.
Old Feb 21, 2005 | 04:27 PM
DirtyDave's Avatar
I have a rattle on the passenger side of the dash and the drivers side. I have drove myself crazy trying to find them. I have done everything but take the dash apart. They are real loud when I am cruising around 60 or 70 mph. I have a Bassani exhaust system and the vibration from it just enhances it. You can't take it back to the service department for a rattle can you?
Old Feb 21, 2005 | 04:30 PM
Dan's Avatar
Dan
Do You Remember Me?
Definately different problems. My sound seems to go away once the car is heated up. I'd check that rattle out David. You can DEFINATELY take it back to the service department. You didn't pay for a rattling car.
Old Feb 21, 2005 | 04:34 PM
DirtyDave's Avatar
Thanks Dan. I will take it by the dealership this weekend and let them listen to it and see if there is anything they can do.
Old Feb 21, 2005 | 04:44 PM
2Slack's Avatar
I found that the cause of a mysterious rattle I had was the passenger side belt-holder not being snapped. It's worth a try.
Old Feb 21, 2005 | 06:40 PM
adrenalin's Avatar
Preacher, do you only notice it on cold days? I have tons of creaks and cracks in my car when it is really cold but when it is warmer out, like 10 degrees they are not so bad.
