Cold Air Intake
Old Mar 13, 2011 | 10:21 PM
bullitt8's Avatar
Cold Air Intake
Hey everyone, I am looking to buy a cold air intake for my 2008 bullitt. I am woundering what the best intake is? I was looking at the C and L racer intake but there are so manyy!Links would be helpfull.
Thank you ,Brian
Old Mar 14, 2011 | 05:31 AM
05YellowGT's Avatar
I believe your bullitt is already an 85mm , so if you're going to upgrade make sure you get something larger. My Steeda is a 90mm ...
Old Mar 14, 2011 | 07:07 PM
RMB427R's Avatar
I have an Anderson PowerPipe on my Roush. They are a little more money than the others, however you do not need a tune with 'em..
Old Mar 14, 2011 | 07:58 PM
Everett's Avatar
Don't buy a metal one cause they suffer from heatsoak and if your gonna buy the cai get one that needs a tune so you can actually get a gain from it instead of a showpiece. Jlt makes a great product
Old Mar 14, 2011 | 08:03 PM
Cusp's Avatar
Thank you ,Brian
What don't you like about the stock cai? That bullitt cai and air pan are the best looking of the lot in my opinion. I think you would get more bang/buck from a tune.
Old Mar 14, 2011 | 11:41 PM
bullitt8's Avatar
Hey, In a accident the intake broke so i am looking for a new one. Should i stay with the ford racing stock one or should I go after market?
Old Mar 14, 2011 | 11:49 PM
bullitt8's Avatar
Hey, Why is the C&L racer intake cheaper then then street if the racer is better?
Old Mar 15, 2011 | 07:33 PM
RMB427R's Avatar
Are you serious?? The 'metal' Power Pipe doesn't need a tune because it includes the mass air meter as a part of the package.
The horsepower gain is 17 at the rear wheels.
Showpiece you say??
Just in case you think I'm nuts..
http://www.andersonfordmotorsport.co...emart&Itemid=1
Old Mar 15, 2011 | 08:19 PM
Bullitt995's Avatar
Racer is plastic and the street is aluminum. Plastic is better if you don't care about looks.
Old Mar 15, 2011 | 09:13 PM
bob's Avatar
bob
All 05+ N/A Mustangs need a tune to work properly with the cartridge style mass-air meter when altering the intake flow path.
CAI's that require no tuning with the stock style meter gain thier power increase by fooling the meter and leaning out the motor.
I see the AFM N/A power pipe requires swapping over to the Abbco DBX mass air meter.
Old Mar 16, 2011 | 05:52 PM
Cavero's Avatar
I've been told Steeda flows the best, i.e. best power. I'd do a dyno tune with whatever way you go. It makes one hell of a difference. I'm just not sure what that does with your Bullitt because that car has an adaptive tune that changes the timing based on the octane of gas it detects. Although that may be a moot point because 99% of all tunes you'll find require 91 or better octane.
Old Mar 16, 2011 | 06:43 PM
pilatti1's Avatar
I put an Airaid on my '07 CS and I could feel the difference with the first ride. Also the sound is better from the stock exhaust. i also did not use a tune as per Airraid it is not necessary.
Old Mar 16, 2011 | 08:20 PM
Doogie's Avatar
Keep in mind that installing any CAI other than the Bullitt version will require an updated tune, so if you do not already have a tuner, you will need to purchase that as well. I would just stick with the Bullitt CAI as any improvement is really only going to come from the tune as any CAI will have similar results.
Here's an old thread that compares the Bullitt to C&L https://themustangsource.com/f669/08...esting-461832/
Old Mar 16, 2011 | 10:33 PM
bullitt8's Avatar
What will happen if I put a intake that a requires tune and i dont get a tune? What dose it mean when the engine runs to lean?
Old Mar 17, 2011 | 03:54 AM
Cavero's Avatar
Your computer will get confused and will enter the a degraded mode (wrench icon will light up on the dash). You'll have really crappy throttle response and will only be firing on 4 cylinders. I ran into this when I first got my Granetelli intake and they sent me a bad wiring harness adapter (it was supposed to fool the computer into thinking the MAF diameter was the same as stock). When the adapter was bad, I tried it without it and got the wrench icon
Old Mar 17, 2011 | 07:21 PM
RMB427R's Avatar
If you add an intake which requires a tune, you'd better get it tuned. As Bob mentioned, all NA Mustangs will need a tune to operate properly.
I didn't want to tune mine because of the warranty. That's why I went with the PowerPipe. You may however need a tune with whatever you decide to go with.
Good luck!!
Old Mar 18, 2011 | 10:53 AM
codeman94's Avatar
I world stay with the stock bullet intake. They are my personal favorite!
Old Mar 18, 2011 | 11:04 AM
topbliss's Avatar
you already have on now.. There will be no difference if you buy another except you being poorer.. Get a tune for your intake you already have and your at the top of your power curve for cai's
Old Mar 18, 2011 | 03:14 PM
jayguy's Avatar
I would stay with the stock Bullitt intake, but get a tune if you want more power.
Your intake is already an upgrade from the stock GT intake, and a tune will wake it up a little more.
Old Mar 19, 2011 | 04:07 PM
Cusp's Avatar
You can get just the FRPP tube, filter and pan for about 250 sans the tuner which you will not need since you already have the bullitt tune.
May 3, 2026 05:42 AM
RoushRS3
Sep 29, 2015 08:03 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
