Clutch Chatter in 1st - Help
Old May 2, 2012 | 05:09 AM
pilatti1's Avatar
When taking off slowly in 1st I get some clutch chatter (mild shaking) only under lower RPM's. Nothing when I rev it higher to take off. What can I do to correct this issue? My '07 GT/CS has 78k and is a daily driver been to the track only 1 time so it is not beat on. Any ideas will be greatly appreciated prior to bringing it to the dealer.
Old May 2, 2012 | 05:58 AM
05YellowGT's Avatar
I believe the disk can get glazed due to driving habits and this can causes it to chatter , assuming of course the clutch just isn't shot. I think there are some threads on here about it so do a search , but if I remember correctly you run it hard for a while and it will burn the glaze off ...
Old May 2, 2012 | 06:04 AM
AlsCobra's Avatar
A Man Just Needs Some....
78k is pretty good for a stock clutch. Flywheel develops hot spots on it in time. Probably about time for a clutch replacement and a flywheel resurfacing.
Old May 2, 2012 | 07:10 AM
wheelman's Avatar
Yup, prolly just normal wear at 78k unless youre better than I with the clutch. Not necessarily the disk either but might want to change the disk anyway if it has to be pulled to inspect/fix.
Gill5oh
Oct 6, 2017 10:50 PM
Kalel08
Sep 29, 2015 03:06 PM
samjluck
Sep 17, 2015 10:24 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
