climate control question
Old Dec 4, 2006 | 11:49 PM
official_style's Avatar
since there is no more "issues" section ill post it here, when i set my vents to blow out the bottom of the dash, it still blows air out on the windshield. it doesnt do it as much as if its set to blow floor and windshield, but when its set on floor it doesnt just blow on the floor. is it supposed to do this?
Old Dec 5, 2006 | 05:54 AM
05RedGT's Avatar
Ford says it was 'designed' this way. I always like my face nice and toasty while my feet are freezing.
Old Dec 5, 2006 | 06:33 AM
Webba's Avatar
I had issues with the heat/ac as well. Id set it to defrost and it barely blew out. My control unit was crap and I took it in for a look and they ordered and installed a new unti under warranty. Seems to be a common issue. Have it checked.
Old Dec 5, 2006 | 06:37 AM
well it still blows out a lot on the floor, i just dont see why there is a setting for floor, and then floor and windshield, if they both do the same thing.
Old Dec 5, 2006 | 08:49 AM
AWmustang's Avatar
They figured no one would notice.
Old Dec 5, 2006 | 12:58 PM
I have to see if my yukon is like this, it has the same kind of climate **** setup
Old Dec 5, 2006 | 01:02 PM
jcthorne's Avatar
This was an 'issue' when the new 2005s came out and is still an issue today. if Ford actually fixed it they would have to install new controllers in all the existing cars too. So they just tell you it is supposed to be that way. Horse puckey, its a design flaw that Ford will not fix as it costs money to do it right.
Old Dec 5, 2006 | 06:03 PM
LBJay's Avatar
My solution, set to Hi-Lo and close dash vents. Works better than setting to Floor and it doesn't have the annoying noise you get out of the dash area when set on just Floor.
Old Dec 6, 2006 | 06:29 AM
302svt's Avatar
Here is a link to another post concerning this issue, I have the same problem with my 07 but havent had time to take it in yet. They say you have to have the control unit replaced.
http://forums.bradbarnett.net/showth...ghlight=heater
Old Dec 6, 2006 | 06:31 AM
jcthorne's Avatar
If you have the control unit replaced and it actually fixes the problem, please let us all know. So far no fix is known.
Old Dec 6, 2006 | 06:36 AM
302svt's Avatar
I will try to find out as soon as I can take my car and post it.
Old Dec 6, 2006 | 06:50 AM
AWmustang's Avatar
Kinda like the Global windows.
And yes I'm STILL bitter about that.
Old Dec 6, 2006 | 02:11 PM
moc1976's Avatar
Me too!
But, I'm also still in love with the car
Old Dec 6, 2006 | 02:40 PM
Webba's Avatar
I have had my control unit replaced and it works like a charm now
Old Jan 28, 2022 | 11:06 AM
Bruce37's Avatar
How much was the new module?
how much was the new module?
Old Jan 28, 2022 | 04:20 PM
houtex's Avatar
Hello and welcome to the forums!
The control unit for the '05-09 is this:
https://www.fordonlyparts.com/2005-2...-8r3z-19980-a/
As an EXAMPLE ONLY, mind, but that seems to be the going rate (about $50 as of this post) for a used Mustang (or other compatible model) HVAC control unit. The unit has the *****, lights, switches, and the logic circuits in it, complete. You can find this part on various websites, including a new Doormat one at AutoSloan which I'd never, ever buy because Dumbman unless I had no choice and wanted to spend four times as much for the privilege. You can also maybe go find one in a salvage yard out of a donor car they have, as long as it's 2005-2009, as they're all the same (I think... not sure about the nav ones...)
Hope that helps, good luck!
Old Feb 27, 2022 | 02:40 PM
mrkabc's Avatar
@houtex I might point out that the 2005-2006 HVAC control unit is different from 2007-2009. I remember this because Silver Horse Racing made aluminum ***** (that I have) that weren't compatible with the 2007+ units. There was a plug/wiring change as well.
Hahahahaha "Doormat".
Old Feb 27, 2022 | 03:18 PM
houtex's Avatar
Hm. Interesting. I wonder if the change is the ***** only, and otherwise the module is the same...?
Ford does Ford things. I still hate I had to cut my perfect wiring harness to swap out a Ford blower motor in the HVAC. It works, and it's the Ford part, but maaan...
jasongt06
05-09 Interior and Audio Mods
Nov 19, 2009 09:48 PM
AKnott
Oct 3, 2008 10:27 AM
packhater
Oct 5, 2006 01:12 PM
Dineau
May 15, 2006 07:17 PM
numberfour
Mar 25, 2005 06:27 PM
