Center support driveshaft.
Old Apr 29, 2013 | 10:17 AM
Red Gt's Avatar
Hello everyone,is there anyone who has a pdf file of the driveshaft from mustang Gt 2005-09 with automatic transmission?
The problem is the center support bracket bearing, this is noisy and needs to be replaced.I need the part number, so I can order this part.Thanks.
Greetings from europe.Red Gt
Old May 5, 2013 | 12:16 PM
Red Gt's Avatar
Nobody?
Old May 5, 2013 | 10:11 PM
bob's Avatar
bob
The center bearing is part of the driveshaft and doesn't have a separate part number.
The driveshaft assembly is 4K145 and the CV joint is part # W708259
Old Dec 3, 2013 | 10:38 AM
Red Gt's Avatar
Finally, problem solved,the local driveshaft shop has made me a 1 piece driveshaft,so no more noisy center support bearing.Mustang runs with only one noice,an that is the rumble from the lovely V8.
Greetings, Red Gt
Old Dec 3, 2013 | 11:12 AM
GrnT's Avatar
Greetings, Red Gt
That an upgrade or modification. Congrats.
Old Dec 3, 2013 | 09:57 PM
ford4v429's Avatar
legacy Tms Member
Greetings, Red Gt
hate to even ask- but they DID put a telescopic end on it right??? dumb question maybe, but years back a guy in here had a one piece one built- and they built a rigid shaft that nearly destroyed his car when it ripped in half on the highway... one would expect any shaft builders to know telescopic movement is necessary, but not all do apparently
Old Dec 4, 2013 | 03:04 AM
Red Gt's Avatar
Yes,they DID put a telescopic end on it,i now that movement is necessary.Thanks for thinking.
Red Gt.
