CDs stuck in radio, any hope getting them out?
Old Dec 29, 2012 | 09:52 AM
Katfish's Avatar
Unhappy CDs stuck in radio, any hope getting them out?
I have an 06 with the Shaker 500 radio. I guess the CD part died, radio still works fine.
Every time I get in the car I can hear it trying to move the CD mechanism.
Only thing display shows is "CD Error" when I try to use it.
At this point I'd be happy to just get the CDs out and use the radio only.
Any ideas how to eject them?
**** UPDATE ****
Here's info I used to remove the radio. Between the 3 links it covers it all.
They really gloss over the elecrical connection removal, you'll need to take your time and make sure to depress the right plastic so you don't break the connectors.
I removed the radio, removed the CDs, and reinstalled the radio in about 1hr.
Radio still works, and the CD mechanism isn't constantly trying to initialize. So I'm happy for now.
http://www.sound-repair.com/index.ph...-instructions/
Old Dec 29, 2012 | 10:00 AM
stupidgenius36's Avatar
Just Plain Rude!
Mine does that every once in a while, and it usually fixes itself after a day or two. You can try unplugging the battery for a little while, and see if that helps.
Old Dec 29, 2012 | 02:05 PM
Womprat's Avatar
Mine are perpetually stuck, wife got me a new radio so the skipper will be gone soon. Nice when it works...
Old Dec 30, 2012 | 09:10 AM
ford4v429's Avatar
legacy Tms Member
I listen to a lot of audiobooks, and noticed a lot of them, and a lot of newer CDs are using thinner plastic-only about .004~.005" if mic'd, but enough the friction rollers that retract the disk wont pull it out...try ejecting with the interior really hot- sitting out in the sun, etc...I have a couple disks with those "CD Stomper" self adhesive printable labels that work fine now, wouldnt eject but barely without...
I had one that was at the slot, wouldnt quite eject enough to grab, pulled the battery cable off before it would suck it back in, was able to put a piece of doublesided scotch tape on a utility knife blade to drag it out by sticking it on top of the disk... the mechanism wasnt very well thought out.
Old Dec 30, 2012 | 09:41 AM
Getportfolio's Avatar
Rip the unit out and use your mp3 from now on. If you don't have mp3, look into it. It's well worth it.
Old Dec 31, 2012 | 01:24 PM
Osiris's Avatar
This happened in my 06 F150. Tried a few times with the battery but it never worked. I had to take the radio out and break it to get the discs.
Old Dec 31, 2012 | 05:21 PM
Mark Fergel's Avatar
You have to pull the unit and dismantle the carriage device in there. It's not too hard. Just a couple of springs and screws. Chances are that one of the trays in it is busted. Most likely this is what's going on.
Here's a bit of info when I ran into it.
http://www.s197forum.com/forum/showthread.php?t=80040
Old Dec 31, 2012 | 05:37 PM
There's another thread that discussed this. May be worth looking into. I remember it because I laughed at how simple the fix was... Maybe the mods can remember it. I wouldnt rip the unit out just yet.
Old Jan 2, 2013 | 09:08 PM
Katfish's Avatar
Tried disconnecting the battery with no luck,
How do I pull the radio out?
Old Jan 2, 2013 | 09:48 PM
Just Plain Rude!
There used to be a pdf on here with instructions, but it looks like the link is dead now. You'll probably have to google around a bit, if no one else here has it already. If you can find it, let me know and I'll tell you as much as I can from memory. It's really not very hard.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
boz
Oct 1, 2015 04:47 PM
DrVet
Sep 23, 2015 01:48 PM
