CAI Installation Question
I just went out and was checking my CAI, I am able to push it down and the tube going into the throttle body moves and almost feels like I could pull it out if I pulled hard enough. Now I didnt install this, I had the shop that did my tuning do it...could it be loose?? Could it be the cause of my car stuttering at WOT?
Anything I can check to make sure its installed correctly?
Depending on the unit itself, it usually has a polyurethane sleeve that covers the intake and joins to the inlet tube. There are two band-clamps with hex bolts/screws that tighten the clamps. The tube on mine is the "Racer" thus plastic and I had to be careful not to over tighten. You can take a 3/8" socket and turn the bolts so the clamps tighten down, just don't use a BIG ratchet, use the 1/4" drive or the smallest you own.
Oh no, ive had it installed for almost a year....it just started doing this lately.....so Iwas checking the connections and noticed that I could move the CAI up and down. So I wasnt sure if I should be able to do that or not.
Ecoboost
7/25/15 06:32 PM
