Brake Fluid Reservoir Markings
Old Feb 18, 2007 | 01:18 PM
metroplex's Avatar
I hear that the "new" reservoirs have the MAX mark approximately in-between the MAX and MIN marks on the "old" reservoirs. My reservoir came out of the factory only a few months ago, so I wouldn't consider it "old" because the original threads were dated early 2006.
So what is the deal?
My MAX mark is right below the top of the flat surface of the reservoir. In between the MAX and MIN mark is approximately 1/2" below the current MAX mark. At the MAX mark, fluid will seep from the cap and dribble all around the reservoir. I have not experimented with a reduced fluid fill level to see if it will slow or solve the seepage. I have a gut feeling the fluid is seeping through the slit of the gasket and out the back, causing it to flow down.
Does anyone have the "new" or "revised" reservoir to compare the height of the markings?
Old Feb 18, 2007 | 01:40 PM
DoctorQ's Avatar
my build date was 5/3/2006, and the MAX mark is just below the top flat surface. I just took in it for the brake fuild leak, and they removed fluid so now the level is about 1/4" below the MAX line (but still ~ 1/2" about the MIN)... we'll see if this solves the leak....
Old Feb 18, 2007 | 05:48 PM
Robbieg's Avatar
My build date is 11/06. I'll check tomorrow and see where the marks are on mine. I did notice a little leaking but I didn't pay attention to the markings.
Old Feb 27, 2007 | 01:37 AM
butterbean's Avatar
Just stick your finger in it and see how fluid you can flush out, that will tell you the max capacity.
Butterbean
boz
Oct 1, 2015 04:47 PM
Rando
Sep 30, 2015 12:28 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
