Brake fluid reservoir marking question
Old Apr 15, 2007 | 04:46 PM
metroplex's Avatar
I recall that when my Stang first came from the factory, the fluid level was very close to the top part of the reservoir, and it would seep out the cap gasket.
I experimented with removing the brake fluid until it no longer seeps out, and tried just keeping it right at the bottom of the MAX triangle (so far, so good). I had it between CAV1 and TRW for awhile but felt more comfortable with a tad more brake fluid in the reservoir.
For those that still have brake fluid seeping out, what is your fluid level and how far from the top of the reservoir (the flat part) is the MAX marking?
Old Apr 16, 2007 | 03:17 AM
metroplex's Avatar
bttt
Old Apr 16, 2007 | 12:32 PM
NJJOE's Avatar
I just put some plumbers tape on the threads and the cap fits very secure. Have not had ANY leaks at all. That way you can leave it maxed out.
Old Apr 16, 2007 | 01:24 PM
metroplex's Avatar
Is "maxed" out right at the tip of the MAX triangle?
Old Apr 16, 2007 | 04:20 PM
Tispco's Avatar
Mine was just ABOVE the word MAX and the triangle from the factory. It was built on 2/20/07. It was not leaking, but I removed brake fluid until was at the bottom of the MAX mark.
Old Apr 16, 2007 | 08:05 PM
Boltzman's Avatar
I have to check mine but I took about 2 teaspoons out and it still leaks a little
Old Apr 16, 2007 | 08:13 PM
06GT4RAD's Avatar
I removed enough to go just below the MAX line and have not had any leakage since.
Richard
joemad59
Dec 30, 2015 06:13 PM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
1001yos
Sep 8, 2015 10:05 PM
Sep 8, 2015 10:45 AM
