Bad O rings
Old Dec 5, 2005 | 09:39 AM
Teri's Avatar
Unhappy
I've got a little over 2,000 miles and the Check Engine Light came on while driving. Thought it was the gas cap and tried that but nothing. Finally, made it to the dealer and found out that the O-Rings were bad. They are ordering them and will call when they come in. Just wanted to know if anyone else had this problem and if I should look out for anything else.
T
Old Dec 5, 2005 | 10:09 AM
Galaxie's Avatar
I Have Admin Envy
which o-rings?
Old Dec 5, 2005 | 10:50 AM
Teri's Avatar
Originally posted by Galaxie@December 5, 2005, 1:12 PM
which o-rings?
OK, I know nothing about engines (and yes I am a woman). I didn't know there were more than one.
Old Dec 5, 2005 | 11:43 AM
lodom's Avatar
An O ring seal is probably used in more than one place in the emissions or fuel system and and could have failed, causing a leak which triggerred emissions code in the computer, thus generating a check engine light. there is another current post on a fuel filter o ring failure. Maybe this is the same problem. More info on where the O ring is located would be helpful in determining failure location.
Old Dec 7, 2005 | 02:31 PM
Teri's Avatar
Thanks for the info. The part is in and I will ask the service rep for details on the problem.
Old Dec 8, 2005 | 11:53 AM
Teri's Avatar
Car is in the shop and I am forced to drive a loaner...Impala (what a downgrade from my pony) until it is fixed. The service rep said that the O-Ring was from the fuel system and they would have to remove the tank and that it was an all day repair. If anyone else has had this problem let me know if there is anything else I should look out for.
Rando
Aug 25, 2021 11:12 AM
GLOCKer
Sep 28, 2015 05:20 PM
tacbear
Sep 27, 2015 12:57 PM
Beouch
Sep 16, 2015 06:14 PM
