Bad Climate Control Module - 2007 GT
Old Jun 12, 2016 | 09:25 PM
kryptonTJM's Avatar
Okay, a while ago I had been having trouble with the blend door actuator on my car. It had been fixed and replaced several times. The mechanic told me that it could be the climate control module that is gong bad as well. Im starting to think he may be right. Today, it was in the upper 90s outside. I had my a/c on and I had the dial turned almost all the way to the maximum cold but not all the way. it felt as if warmer air was blowing, so I moved all the way to the end of the blue side, then the cold air started coming. I don't know if the heat had an affect, or if the a/c was just working harder because of the high temperatures. does this make any sense?
Old Jun 13, 2016 | 07:28 AM
Paris MkVI's Avatar
Have you had any unpleasant, strong smell in the cabin? Just asking - it might be the evap core.
Old Jun 13, 2016 | 10:44 AM
07 Boss's Avatar
I thought you replaced that a while ago already. Saw some on ebay used for like $40-$50.
Old Jun 14, 2016 | 05:39 AM
kryptonTJM's Avatar
I haven't yet, I just ordered one last night. I also had to order another actuator as well.
Old Jun 14, 2016 | 05:41 AM
kryptonTJM's Avatar
No, no smells or anything. The temperature here lately has been in the 90s with a heat index of 105 so it might just be the heat
Trumpetlon
Jul 14, 2016 03:03 PM
Da_Blue_Deamon
Jun 11, 2016 07:52 AM
Ponyforher
1994-2004 V-6
Jun 9, 2016 09:32 AM
