automatic transmission hesitates
Old Dec 4, 2016 | 05:08 PM
rick57's Avatar
When I go to take off sometimes it dosent go like its in netural for a second then takes off. some times it squeels the tires if i try to take off in a bit of a hurry.
It dosent seem to be slipping just hesitates for a second sometimes. It did it like once a week or so. SO I had the fluid changed now it seems to do it more often. THE longer I sit still the more likely it seems to want to do it.
car has 120,000 miles. I heard if the fluid hasnt been changed ever then dont change it. just got the car a year ago so I had it done.
going to drive it 2,2000 miles next month wondering if its headed for a problem
Old Dec 5, 2016 | 06:29 AM
check the fluid level. I know there no dip stick but there is a way to check it. But its never good news when the trans starts doing this.
Old Dec 5, 2016 | 04:32 PM
KdF's Avatar
KdF
Does the RPM's rise then slam into gear? If so the pump in the transmission is going out. If it seems that the throttle lags, there are plenty of threads here that explain how to reset the gas pedal for response.
Old Dec 7, 2016 | 11:12 AM
07 Boss's Avatar
Could be the pump, but more likely the solenoid pack or servo bores. Either way you're going to have to have some work done. That is if the fluid level is fine. That would be the first thing I checked.
Old Dec 9, 2016 | 04:13 PM
rick57's Avatar
yep rpm's go up and slams into gear
Old Dec 9, 2016 | 04:14 PM
rick57's Avatar
had the trans fluid changed at the dealer now it does it worse and more often
Old Dec 9, 2016 | 04:51 PM
KdF's Avatar
KdF
I see a rebuild in your immediate future. The longer you drive it, the worse it will get until it moves no-more. It's got 120K on it, well past it's prime for a American Tranny.
Old Dec 10, 2016 | 12:35 PM
start keeping an eye on the local bone yards and ebay for a replacement. What else did Ford have to say about the your trans?
Old Dec 15, 2016 | 05:55 AM
ford4v429's Avatar
legacy Tms Member
*can* a tuner be used to adjust pressure on a ford? dunno, dont have a auto...but think all 'throttle valves' used these days are proportional solenoids - as such, might be adjustable.
my mom had a impala with a sticky throttle valve, common on a chevy, cost 2200 to replace as half the car has to come apart to remove it, so she traded it in...i couldnt help but wonder after the fact why a detergent couldnt be used to clean varnished up solenoid spools(similar to yours- they still work, but 'stick' and pressure builds harshly once overcoming whatever is gumming up the spool...), or if a tuner could simply be used to dial up increased pressure at idle- a firm light throttle shift would be better than a slipping transmission burning clutches between neutral drops...dunno, just always wondered...
would bet theres some kind of detergent with defoamer out there compatible with ATF... lastly- around here many dealers use recycled oils, bought by the drum...sure it meets required specs, but always wondered if good as it could be...we ran recycled hydraulic oil at work for a year(hundreds of machines) and had lots of weird hydraulic issues...not a fan. lately read how some ATF flushes actually filter/recycle oil right in the 'machine' on site...filtering old oil, putting some additives dont sound as appealing as fresh for some reason...but with sticky valves, sure seems a detergent could be added...
Old Dec 17, 2016 | 10:41 AM
hobojack's Avatar
Servo bores wear out causing sticking servos. Common issue with these transmisson. Mine would slam in reverse,but not all the time. Left alone it will eventually snap the band. I had the fluid changed and when I got it back I had other issues. Replaced with a reman. trans from ford.
Old Apr 24, 2017 | 07:52 PM
rick57's Avatar
fixed
finally got my password working again.
They said the planet gears were coming apart brass every were in there.
has been fine so far
