Auto Up window not working after 1000 miles
Old Feb 6, 2007 | 06:58 AM
cmsurfr22's Avatar
ok has anyone else experienced this problem? i've got 1200 miles on my 07 mustang gt and the automatic up on the windows intermitently doesn't work.
Old Feb 6, 2007 | 07:02 AM
Cheese302's Avatar
has the battery ever gone dead on you?
try holding the switch and cycling up and down a few times see if they just need to reset.
if not take it to the dealer
Old Feb 6, 2007 | 08:14 AM
DynamicmustangGT's Avatar
Could also be a water problem somewhere in the car, a loose connection, or a short, well worth having checked out its under warranty might as well
Old Feb 6, 2007 | 12:13 PM
sodaman's Avatar
yah you may want to read up in the manual. I remember someone saying they had some steps you follow when having problems with the auto up etc. good luck
Old Feb 6, 2007 | 01:14 PM
theedge67's Avatar
Restoring the Express up functionality (Front windows only)
Under low battery power conditions, Express Up only functionality may
be lost. To reset this function after restoring full battery power, pull the
switch to the Express Up position, hold the switch until the glass
reaches the stall position and continue to hold for 2 seconds. Push the
window switch DOWN and operate the window to the full down position.
Express UP will now be functional. Perform Express UP
re-calibration with door closed only. Calibrating with door open
will cause the window to continuously bounce back.
Owners manual online for '06, probably almost exactly the same as '07... https://web.msslib.dealerconnection....000c588053025a
Old Feb 7, 2007 | 11:15 AM
RaGsHoCkEy88's Avatar
this happened to me the other day...sunday at the gas station...hold the window up button for like 3 seconds u should be fine
steiblerm
Aug 16, 2015 05:05 AM
09-gt/cs
Aug 14, 2015 08:52 AM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Earlsays
Jul 14, 2015 05:25 AM
