Auto up window not working
Old 4/8/16, 08:25 AM
SpectreH's Avatar
Received 1,155 Likes on 843 Posts
The manual only calls out the rear windows specifically in the manual, so it should work for convertible door glass as well. From the 2013 manual:
POWER WINDOWS
Pressor lift the switches to operate the windows.
Press the switch to the first detent and hold to open the window.
Lift the switch to the first detent and hold to close the window.
One-Touch Up or Down (Front Windows)
This feature automatically opens or closes the window.
Press or lift the switch completely and release. The window will fully open or close.Press or lift it again to stop the window.
Restoring the One-Touch Up Functionality
Note: Perform one-touch up re-calibration withthe door closed.
Calibrating with the door open will cause the window to continuously bounce back.
Functionality may be lost under low battery power conditions.
To reset this function after restoring full battery power:
1.Pull the switch to the one-touch up position.
2.Hold the switch until the glass reaches the stall position and continue to hold for two seconds.
3.Press the switch down and operate the window to the full down position.One-touch up will now be functional.
Bounce-Back
The window will stop automatically while closing and reverse some distance if there is an obstacle in the way.
Overriding the Bounce-Back Feature
Pull up the window switch and hold within two seconds of the window reaching the bounce-back position. The window will travel up with no bounce-back protection.The window will stop if the switch is released before the window is fully closed.
Short Drop Glass (Front Windows)
This feature lowers the glass when either door is opened to improve door efforts and sealing. The glass returns to its closed position when the door is closed.
Re-Calibrating a Window
Note: Perform short drop re-calibration with the doors closed.
Re-calibrating with doors open will cause the window to continuously bounce back.
If a window will not raise again when the door is closed, use the switch to fully raise the window, then hold the switch up for two seconds.
If a window will not lower when the door is opened:
1.Use the switch to fully lower the window, then hold the switch down for two seconds.
2.Immediately after releasing the switch, pull the switch up to fully raise the window and hold the switch up for two seconds.
Rear Power Windows (Convertible Only)
The rear quarter windows are operated by a single switch located at the driver’sdoor window controls.
Press and hold the switch to open the windows.
Pull up and hold the switch to close the windows.
Manual Override
The rear quarter window switch will not operate when:
the convertible top is moving
the convertible top is not completely up or down.
The rear quarter windows can be manually raised if the switch does not operate when the convertible top is completely up or down.
The following procedure must be performed within two minutes:
1.Switch the ignition off, then back on.
2.Press the rear window switch down three times.
3.Switch the ignition off, then back on.
4.Pull the rear window switch up and hold it for three seconds. The rear windows will begin to start moving up.
Accessory Delay
You can use the window switches for several minutes after you switch the ignition off, or until either front door is opened.
Old 4/8/16, 01:23 PM
karman's Avatar
Originally Posted by luvebug
Hi Deysha,
does this also works with a convertible?
Make sure the door is closed and the top is up
Old 4/27/16, 04:22 AM
luvebug's Avatar
Hi Deysha,
Hi, my local dealer told me that this never going to work with a convertible.
I have tried but it does not work. Windows open works. but close just goes to manual. Would you check this again please?
Old 4/27/16, 04:25 AM
luvebug's Avatar
Tis is an EU version. Maybe that's the reason why it does't works.
Old 4/27/16, 06:44 AM
Just Plain Rude!
stupidgenius36's Avatar
So, 3 possibilities:
1. You did something wrong. - Try it again.
2. You have a different problem.
3. Perhaps the auto-up has been disabled on your car, as a safety issue. - I've never heard of this happening.
To be honest, saying that the re-calibration isn't working...is something I'll never believe unless I see it in person. I also don't think the dealership would have any idea what they're talking about, so I'm extremely skeptical about their opinion.
Old 4/27/16, 02:39 PM
luvebug's Avatar
He told me that it had something to do with safety. Fastback works, convertible not.
Old 4/27/16, 06:17 PM
goldenpony's Avatar
I have to recal my windows 2-3 times a year. No big deal. Mine is a 'vert.
Old 5/1/16, 03:24 PM
mrkabc's Avatar
Convertible here, the recalibrate function works for me as well.
Old 5/1/16, 04:08 PM
luvebug's Avatar
but is your stang a 2015 model?
Mine does not works.
Old 5/2/16, 06:34 AM
Just Plain Rude!
I think everyone here has, and is referring to, an S197. Have you had a 2015 this whole time? This thread is in the S197 section. I think it's time for you to start your own thread...in whatever section is appropriate.
Old 9/27/16, 08:41 PM
dylanavery11's Avatar
Originally Posted by FordService
Hello Katfish and MustangGod,
My name is Deysha with Ford Customer service. Katfish, glad to hear you were able to get your window working properly again thanks to our awesome members. MustangGod, the info to re-calibrate the windows is in your owner guide and this info is good for 2005-newer:
Restoring the Express up functionality (Front windows only)
Under low battery power conditions, Express Up only functionality may
be lost. To reset this function after restoring full battery power, pull the
switch to the Express Up position, hold the switch until the glass
reaches the stall position and continue to hold for 2 seconds. Push the
window switch DOWN and operate the window to the full down position.
Express UP will now be functional. Perform Express UP
re-calibration with door closed only. Calibrating with door open
You can also find your owner manual at: https://owner.ford.com/servlet/Conte...&model=Mustang. I hope this helps! Have a great weekend!
Deysha
My window will not roll down the 1/8". I can open the door okay by pulling hard. However I have to turn car on and roll window down, close passenger door, then roll window up before removing keys from ignition. The issue started a couple months ago. May have happened as a result of having locksmith open vehicle, but not absolutely sure.
I have tried the recalibration 20 times with no luck.
2005 Mustang V6 fastback
Old 9/28/16, 08:28 AM
07 Boss's Avatar
Then you need a new window control module.
Old 9/28/16, 10:15 AM
Originally Posted by Gravydog316
Try disconnecting your battery & letting it sit for 15 mins., & try again.
I had to do that after I got a new battery.
No luck with that.
Old 9/28/16, 10:34 AM
I didn't think the window control module had anything to do with the auto up/down feature?
Old 9/28/16, 11:16 PM
GrnT's Avatar
Did you try bringing the window all the way down and all the way up while holding the button? That's how you reset the window up/down feature.
You have to keep holding the switch for full travel both ways. If that doesn't work then I'm not sure.
Old 9/28/16, 11:33 PM
Yes, many times. Scroll down, hold for 2 seconds, scroll up, hold for 2 seconds
Old 9/29/16, 09:32 AM
07 Boss's Avatar
Well when you are doing that down, hold, up, hold procedure it is supposed to be resetting the window control module so if that is not resetting it I'm going to make the logical assumption that the module is bad. But you know what they say when you assume.
The only other thing that it could be is that your door sensor is not working but you haven't mentioned any issues like the interior lights staying on or anything like that so I kinda ruled that out.
Do both windows not work or just your side?
Old 9/29/16, 09:44 AM
Door sensor definitely works. Like I said, the window works, just not the auto down/up feature. Just the passenger window is having the issue
Old 9/30/16, 09:42 AM
07 Boss's Avatar
Well it sounds like the module is out. I would see if you can source a used one locally. I know that there are few different colors that ford uses.
http://www.ebay.com/itm/BLUE-FORD-MU...xXP9jj&vxp=mtr
But I would check with your local dealer to verify part numbers and compatibility.
I'm not sure if there is a module in each door or one central one. But if you have one in each dooor I might try swapping them from door to door to see if the problem follows. That would insure that we are on the right track.
Old 1/25/19, 05:50 PM
  #40
Mustang807952's Avatar
Thanks. Excellent. It functions in my 2007 gt. !
Originally Posted by Glenn
its in thew owners maunal. I think you roll the windows down and hold the button down for 2 seconds then roll it up and hold the button up for 2 seconds. I think thats it. But check the book. I have to reset mine way to often. I don't know of any other car you have to do this with.
Quick Reply: Auto up window not working
