anyone know how to remove the center vents?
Old Jul 13, 2007 | 04:19 PM
official_style's Avatar
i got a rattle behind the pass airbag/center vents. how do i remove the center vents? it seems like i need to remove the pass airbag cover. does it just pop off? im kinda a little scared to mess with it and have the bag blow up in my face.
Old Jul 13, 2007 | 04:56 PM
davisinla's Avatar
Make sure that's really where the rattle is before you dig into it...my dash has rattles too, but they are very elusive.
Old Jul 13, 2007 | 05:01 PM
05fordgt's Avatar
To remove the center section, you HAVE to remove the entire airbag assembly. All you need to do is have the airbag unit pushed out enough, for you have access to the top screw that hold down the right side of the center vent. Then remove the trim ring over the steering column (a firm tug will do this), and take that screw out. Lastly, you have to slid the side panels that are along the center stack (radio). Pop them out enough to get to the screw behind each, and your set to go. To get these vertical pieces out, you may need to loosen and move the whole center console a little. Its tedious, but its how it needs to be done. We removed the center panel for a customer, who sent his from his GT500 to Shelby for a signature.
Old Jul 13, 2007 | 05:07 PM
well i have taken the whole dash apart before, except the airbag part. basically i want to know where the screws are for the center vents on the passanger side. so if i pull out the 2 kind of doors that cover the pass airbag, i can get to them and it wont blow up?
Old Jul 13, 2007 | 06:14 PM
Robbieg's Avatar
I would disarm the air bags just to be safe.
Old Jul 13, 2007 | 08:16 PM
JonCo's Avatar
I... Would take it to Ford? See what they can come up with. I know the A-Piller does a annoying rattle sound. Have you tried that first? There some threads around which go into detail about it.
Old Jul 16, 2007 | 07:06 PM
and pay them $92.00 per hour for labor? i have warranty delete already.
how do i push the airbag forward? from under the dash, or pull it thru the 2 covers over it on the front of the dash?
Old Jul 16, 2007 | 08:31 PM
Got Oatz's Avatar
Not sure, but perhaps these will help....Please be careful...
http://www.2005stang.com/gallery/alb...g%20safety.pdf
http://www.2005stang.com/gallery/alb...s%20airbag.pdf
Mike
Old Jul 17, 2007 | 12:45 AM
yeaaah i think im gonna take a pass on this one and live with the rattle. goddam complicated cars nowadays.
Old Jul 17, 2007 | 09:00 AM
kevinb120's Avatar
If you are still under warranty mileage it should be covered And you are sure its not the vent itself or the A-pillar?
Old Jul 18, 2007 | 07:03 PM
the rattle is coming from behind the pass airbag. if i bang on the dash there i hear it.
Old Jul 18, 2007 | 07:50 PM
got the info needed from the pdfs.. thx.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
