active anti theft?
active anti theft?
- Just traded in my 05 for an 07. On the sticker, it says I have active anti theft, I assume its some kind of alarm,but don't really know much about who it works, so if anybody knows, please fill me in. Thanks
I have it on my 06. In a nutshell there are motion detectors in the map light console above the rearview mirror and tilt sensors somewhere that determine if your car is being jacked-up or towed. The motion detectors will sense movement inside the car after it's set.
The alarm is a 2nd horn different from the normal horn and the system is activated by pushing the lock button on the key fob twice. The horn will chirp. There is no sound made when the car is dis-armed.
Roll down your windows, push the lock button twice, wait a few seconds and then stick your arm inside the car and wave it.
In other words, you can't set it without your car's key fob.
I
Also, you can arm the system by pushing the lock button on the inside door panel before you close the door.
If you want it armed without the motion sensors and tilt sensors active, lock the pass. door manually by pushing down the lock pin. Then lock the driver door with the key in the door cylinder.
Check out the owners manual, it details all of this for you. Online at https://www.fleet.ford.com/maintenan...ls/default.asp
9/8/15 10:45 AM
