Accessory Delay?
Old Jun 30, 2006 | 01:31 AM
Arizona Stang's Avatar
Accessory Delay?
How do you disable it? I can't find how to disable it in the manual all the manual says about it is what it does.
Old Jun 30, 2006 | 08:24 AM
05RedGT's Avatar
Why do you want to disable it?
Old Jun 30, 2006 | 09:54 AM
StangNut's Avatar
You can't disable it. What does it say exactly in the manual... and what page?
Just open the door and there's no more power to your accessories.
Old Jun 30, 2006 | 02:54 PM
It says to use the Global windows feature (opening your car windows with your anti theft fob) then the accessory delay needs to be turned off.
Old Jun 30, 2006 | 02:55 PM
Page 65.
Old Jul 1, 2006 | 04:53 AM
So no one knows how to turn it off?
Old Jul 1, 2006 | 07:36 AM
AWmustang's Avatar
A dealer has to turn it off. they have to connect their computer to the car's computer. But if your car was built after the end of april 05 it won't matter since the windows won't work for you.
Besides I'm fairly certain that those people who have the working global windows also have working accessory delay.
There are a ton of threads on the global windows, do a search.
Old Jul 1, 2006 | 09:58 AM
Zig-Zag's Avatar
What this means is that the global windows will not function while the accessory delay is active. IOW, the period after the engine is turned off but before the door is opened. AFAIK, it is not possible to bypass the accessory delay.
Old Jul 1, 2006 | 10:23 PM
StangNut's Avatar
What it means by turning it off is opening the door.
You can't diasble it.
Old Jul 3, 2006 | 05:24 AM
05RedGT's Avatar
The global windows function is for opening the windows from outside of the car with the remote so the accessory delay will be off already.
Old Jul 3, 2006 | 02:16 PM
But when I press and hold lock/unlock on my key fob the windows don't go up or down.
Old Jul 3, 2006 | 02:43 PM
sodaman's Avatar
thats because they stopped making them with that option. only way you can try to get it too work is go into your dealer, and ask them if it can be enabled. I did that on my 05 and they turned it on. But soon after that they built the cars with out the necessary equipt and comp programming. So if yours is a late 05 or 06 etc. You will not be able to get them to work without a lot of work and adding on parts etc. Second option is the best, buy a remote starter kit that still allows you to use the factory alarm, but also has upgradable options. On my 06 gt I added the remote starter which is awesome in the winter, not too bad in the summer either if you leave your ac on when you shut the car off. But the nice thing is on the upgradeable remote start I can also pay 100 bucks and have them add the auto window upgrade, both up and down positions from remote. So if you are unable to have them turned on by the dealer get a remote start with some upgradeability and add them on yourself. Good luck
I think its a viper remote start, I told them I wanted to continue using the factory alarm, so they have that option shut off, remote start turned on, and global windows all from one remote. They will need your second key tho to add it to the car for the remote start. Later hope this helps you out in the future.
Earlsays
Repair & Service Help
27
Feb 25, 2023 03:17 PM
JT_Kwik
Nov 29, 2022 01:45 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
rickey7575
Aug 21, 2015 11:40 PM
