4.6 3V tick tick tick sound
Solved!! Best tool I have is a long *** flathead screwdriver. I checked everything. Changed my oil. I looked all over the net. I was really starting to think it was a bad cam follower. Nope. I used the long flathead and stethascoped the cylinders and the one on the driver side front was by far the loudest. So I pulled the plug and noticed it was REALLY loose. Oops. That's right! Loose plug. I feel like a dummy BUT if this helps at least one person it was worth it. Thanks for the help peoples!
legacy Tms Member
1) 08 was the year they revised the heads mid year- does yours have the extended tip or newer 'normal' plugs?
2) were the plugs ever changed?
glad you found it- more glad that you checked/found before the threads blew - hopefully this isnt a common failure mode- but with the issues Ford had with the blow-out 5.4 truck plugs and then the break-off early 3V plugs, it wouldnt surprise me
awesome! but now I got a couple questions:
Rando
8/25/21 11:12 AM
