3V Cam Install Video, Brenspeed Detroit Rockers & Freedom Racing Tools
We thought you may enjoy this video on using Freedom Racing tools for a 3V cam install. If you need more info on these tools you can use this link below to head over to www.brenspeed.com
FREEDOM TOOL AND DIE 3v VALVE SPRING COMPRESSOR
The above link is for the 3V valve spring compressor
FREEDOM TOOL AND DIE 3v TIMING CHAIN WEDGE
The above link is for the timing chain wedge tool
We use both the above tools on a weekly basis at our installation facility. They have worked out very very good over the last couple years! Also they are MADE IN THE USA!!!
Here is a couple video's of the Brenspeed Detroit Rocker Camshafts! You can also see our camshaft line up online using this link
Camshaft <--- click "Camshaft" to check out 3V cams
