2008 Gas Cap tether vs 2007 Gas cap tether
Old Aug 28, 2007 | 05:46 PM
metroplex's Avatar
Cool 2008 Gas Cap tether vs 2007 Gas cap tether
I noticed that the 2008 GT's gas cap tether is shorter and tied to the center of the hinge on the fuel door, while the 2007 GT's tether is much longer and bolted to the base of the hinge/door area. I have found that the 2007 tether rubs against the hinge and sometimes gets jammed up because of its length/location.
The 2008 design appears to be much better, but there doesn't seem to be an easy way of adapting it to the 2007. Does anyone have any ideas?
What type of tether system does the Ford aluminum fuel door use? I know this isn't a big deal but it's something that irks me whenever I gas up since i have to make sure the tether isn't caught between the door or something.
Old Aug 28, 2007 | 06:13 PM
07 HOSS Mustang's Avatar
"I dont need no stinking tether"
Old Aug 28, 2007 | 07:11 PM
Deric's Avatar
On the subject of gascaps I hate how there's no place for the cap when it's off and it has to hang making contact with the body. My wife's camry has a small lip on the inside of the door and the cap will set on it holding it in place. It is one of the things I wish my mustang had
Old Aug 28, 2007 | 07:13 PM
karman's Avatar
Yeah, cut it off and put the cap on top on the pump like God intended it.
Old Aug 28, 2007 | 07:21 PM
antdog's Avatar
Old Aug 28, 2007 | 08:05 PM
titanjc's Avatar
Same here, I think about that every time I'm filling up.
Old Aug 28, 2007 | 09:53 PM
n00bstang's Avatar
i wish our gas caps were locked.
Old Aug 29, 2007 | 06:51 AM
Boomer's Avatar
I bought a locking one...
The tether I just tuck up... and the door closes fine.
No big whoop
Old Aug 29, 2007 | 07:14 AM
metroplex's Avatar
You can pry apart the gas cap to remove or swap the tether and snap it back together (versus just cutting the tether).
Old Aug 29, 2007 | 08:15 AM
I bought a locking cap and keep the original in the trunk for when I leave the locking one on top of the pump somewhere. NO TETHER
Old Aug 29, 2007 | 08:25 AM
Silverback's Avatar
Buena buena!!!
Old Aug 29, 2007 | 09:17 AM
krnpimpsta's Avatar
Yeah, I don't like the way the tether naturally orients the gas cap - gasoline-dripping-side rests on the side of my car. I've only filled up twice so far, but each time I dabbed the area dry with my shirt (would you rather have gasoline on your shirt or your paint job??? ).
If someone made an aftermarket gas door that had a place to rest the cap, that looked stock on the outside, I would definately buy it.
Old Aug 29, 2007 | 10:42 AM
metroplex's Avatar
What I have done with my 07 gas cap is pull it down and orient it so that it doesn't touch the car. Then I start filling up. However I haven't found an easy way of re-aligning the tether when I'm closing the door. The 2008 seems to solve this issue. I wouldn't mind springing for the $100 factory alloy cover if it was designed better.
Old Aug 29, 2007 | 12:37 PM
2k5GTC's Avatar
I don't see the problem with the pre-shorty teather. You take off the cap, pull it out toward you and slowly put the cap down. My teather keeps the cap from touching the car.
Old Aug 29, 2007 | 02:30 PM
karman's Avatar
That is what I do.
(old man rant)
"When I started drivin' they didn't have tethers and we liked it."
Old Aug 29, 2007 | 03:03 PM
I hate those things, I can see their use, but I hate them.
Old Aug 29, 2007 | 07:18 PM
Dougxox's Avatar
Originally Posted by karman
That is what I do.
(old man rant)
Yeah and when we lost one we just shoved an old rag in the top to keep the dust out.... hmmm isn't that a rolling molatoff cocktail?
Old Aug 29, 2007 | 07:23 PM
karman's Avatar
I deleted that part before I posted. (I really did)
I didn't want to give any of the kiddies funny ideas.
I never did it myself but it was very common back in the day.
Old Aug 29, 2007 | 08:42 PM
randy_tho's Avatar
Yeah. None of those pesky emissions systems to get in the way. No dash light to come on if the tank cap is missing.
Old Aug 29, 2007 | 08:46 PM
Little Black Pony's Avatar
Huh, I've never had an issue with my gas cap tether on my 07. My cap hangs about 1/2 'n inch away from the quarter panel.
