2005 gt drivers side seat
Old Jul 6, 2018 | 11:50 PM
2005gtx's Avatar
Ok call me ocd but I'm going crazy
tbis seat has so.many adjustments and my girl moved it
Should the bottom of the seat be all the way down to the floor? Is that it's normal position or up a little
Old Jul 7, 2018 | 04:35 AM
2005gtx's Avatar
How high should it be
Old Jul 7, 2018 | 05:06 PM
2005gtx's Avatar
Ok thanks
so just put it all the way low and then raise it a little ?
Old Jul 7, 2018 | 08:13 PM
houtex's Avatar
We cannot advise you where to put the seat for you. I like mine higher and more flat with zero lumbar and not so much lean back, my brother likes his back and down, some lumbar and a considerable lean...
You position it for you. You'll find it. I have every confidence. Good luck, and welcome to the forums!
Old Jul 7, 2018 | 08:14 PM
2005gtx's Avatar
I want the seat part flat
Old Jul 8, 2018 | 03:27 PM
wanted33's Avatar
Seat positions are quite relative to the individual owner. If you want the seat bottom flat you will need to use a little twisting action on the front/back switch. Twisting/Tilting the switch will rock the seat instead of moving it up, and down.
Old Jul 9, 2018 | 06:32 AM
Don't sit in the drivers seat at all. I think its to high yo
