'08 Convertible rear window issue
Good evening! Let me start by saying I am far from a mechanic, so I'm hoping this is a simple fix.
The rear passenger window will not go up. When I pull up on the window switch it will go up about an inch, pause and then go back down. I tried to help it up while lifting on the switch but it was still pulled down.
Trying to find another thread before posting I did see a suggestion to press the switch down 3 times, however, because the window is down, I don't have any way to grab it. I'm hoping not to have to take it apart in order to fix this because as I said, I'm not a mechanic and not really skilled.
Any suggestions (after laughing at me) will be greatly appreciated. Also, feel free to phrase any instructions as if you're explaining it to a toddler.
Thanks!
Thanks!
It's CONVERTIBLE with an I and It Looks Like a Lot Folks Get That Wrong. May help with Search a Bit~
Man I got a Ton of Typo's on Vert Topics Going Way Back That Could Keep Me Busy! Aye Carumba!
No Worries I have Spelling Errors All the Time!
Here is a Previous Topic I Put Some Helpful Info in!
https://themustangsource.com/forums/...sition-549556/
Welcome to TMS.
We Don't Laugh at Folks! At Least not on my Watch!
KC
Welcome to TMS.
KC
Thank you! I thought I had fixed that when I gave you the like. I must be more exhausted after Monday part II than I thought. Clearly not only am I not a mechanic but far from a Rhodes scholar as well.
Wait till you Read all the PDF'S in Other Forum and Start Checking Stuff, Then you will be Tired! My Best Suggestion is Print em Out and Just Work the Problem.
KC
KC
