05 Best MPG?
#41
it's best when it is spring time here in PA, only about 68 degrees, not too hot or cold just perfect*. Forget it in the summer, too darn hot!! Anything above 95 degrees - - - A/C here I come!!
Matt
Matt
#42
[QUOTE] average 25.5-26.0, mostly highway. On the interstate today, I set the cruise @70, punched it up to 85 a couple of times to pass, and averaged 29.2 mpg over 185 miles. Had a real good tailwind, though.... [/ QUOTE] Wow! you got a good car. I'm averaging 21 MPG and I'm doing mostly highway trip. Maybe it will be better this summer...
#43
Originally posted by 05WindveilGT@March 21, 2005, 4:40 PM
I just want you to know that I'm not trying to flame you (accadian & awmustang), I just thought I'd pass on knowledge of this aera of automobiles as I do have some knowledge. As for the link, I believe on the Discovery Channel (Mythbusters) they ran 2 Explorers with the same amount of gas one @ 55mph, one with windows open and one with A/C turned on. The Explorer with the A/C on ran out of gas while the opened windowed Explorer ran about 25 more miles.
Matt
Matt
How close was the milage?
Was the frond end allignment the same?
powertrian in the same shape?
Tire pressure?
A/C charge?
All of the above can have a significant effect in fuel efficiency.
Another problem I have is that they ran the AC as high as it would go. They guy had a coat on it was so cold in there. No one would practically run their AC at that rate. Running it at a lower level causes the compressor to cycle less. The compressor isn't running constantly.
If you want me to buy that test, run it twice with each vehicle switching roles and run the AC at a reasonable rate.
I still don't buy that AC uses more gas. I'd like to see some proven facts, not claims of knowledge.
#44
, you think that in a vigorous test all of those procedures would be taken into consideration. We are not talking about the degree of air comming out of the vents. Basically just if the condensor and evaporator are ON. I have facts, not links, I would like a link to show that the A/C does not take away more gasoline. Think about it simplistically - turning on something that doesn't needed to be turned on, needed energy to supply that mechanical device.
Matt
Matt
#45
Matt
Matt
Not flaming anyone here as much as I am that TV show...whick I normally love but that episode somehow pissed me off. Man, I have issues...
#47
Let's come to a general conclusion, both the A/C and riding with windows down @ highway speeds do contribute to the loss of gas milage. Which one contributes more?? Leave it to the statistics.
Matt
Matt
#49
Originally posted by jwede@March 21, 2005, 7:24 PM
The AC does use more gas, but so does having the windows down.
#50
Matt
Matt
#52
Myth Busters are a Myth
That test they did was not done as well as most 8th grade science class project. They could not run at the speed they needed on the track and messed around, they are a waste of air time.
They have just as much of a chance of being right as flipping a coin.
#53
Originally posted by davam1@March 19, 2005, 11:19 AM
Has anyone achieved 28mpg in HWY driving out there? Also, what are some ways to achieve better fuel economy? I understand the cars are tuned to burn richer out of the box. Is it just a matter of a retune, if one is concerned about this? Or are there some mods that can be made (cold air intake, etc..) to improve mpg?
Any info on this would be helpful. Running 87 certainly helps.
#54
Matt
Matt
http://www.cartalk.com/content/columns/Arc...994/May/05.html
Though, some would say they have no more credibility than the Mythbusters. Either way, if you are truly worried about the gas mileage, drive with the windows closed AND the A/C off.
#55
Originally posted by AWmustang+March 22, 2005, 9:14 AM--><div class='quotetop'>QUOTE(AWmustang @ March 22, 2005, 9:14 AM)</div><div class='quotemain'><!--QuoteBegin-05WindveilGT@March 21, 2005, 7:18 PM
Matt
Matt
[/b][/quote]
And Don't buy a Mustang either!
#56
Originally posted by 05WindveilGT+March 22, 2005, 11:03 AM--><div class='quotetop'>QUOTE(05WindveilGT @ March 22, 2005, 11:03 AM)</div><div class='quotemain'>
It took a while, but I found the link.
Matt
Matt
[/b][/quote]
That's it. After all this, I'm gettin a Humvee!!!
#57
Originally posted by davam1+March 29, 2005, 9:51 PM--><div class='quotetop'>QUOTE(davam1 @ March 29, 2005, 9:51 PM)</div><div class='quotemain'>
Matt
Matt
[/b][/quote]
Oh god an upscale Tonka truck!! please nooo!! :notnice:
Matt
#59
bah humbug. having to TRY to save a few bucks ruins the driving experience. gas is cheap here, even if it was $2.50 a gallon. My Focus SVT only averages about 20mpg and requires premium gas. Mustang GT's are misers. like was said earlier, if your'e worried about gas mileage, drive a prius, it only takes about 10 years to make up the extra cost of the car in gas saved over a well-equipped, safer, better handling standard-issue 05 Focus People worry about gas mileage, when it reaches the price of bottled French water I may get upset about it.
