wtf!!!!
Old Jan 12, 2011 | 09:48 AM
shaunrc's Avatar
wtf!!!!
Ok I have a question my car will drop down to about 400 elms here and the when I come up to a red light and died on me one time when I was pulling into a parking spot and once again when I was backing out and im thinking it could be the alternator but im not a tech so I don't really know can anybody help me out
Old Jan 12, 2011 | 03:20 PM
Onesickstang01's Avatar
I bet it's the IAC. Pretty common on fords. Pretty cheap and very easy. Right on front of the throttle body. Has a tube going to the intake hose as well as a two wire elect plug
Old Jan 12, 2011 | 03:23 PM
Agreed. Search "clean those throttle bodies".
Old Jan 12, 2011 | 05:18 PM
when was the last time you did general maintance on it? Air cleaner, spark plugs, fuel filter?
Old Jan 12, 2011 | 06:42 PM
shaunrc's Avatar
Are you talking about the tube with the black box on it what exactly does iac stand for lol
Old Jan 12, 2011 | 08:10 PM
houtex's Avatar
Idle Air Control Valve: http://www.2carpros.com/articles/how...ol-valve-works
scroll down for the description and symptoms and such.
And as asked before: Cleaned your throttle body lately?
Old Jan 12, 2011 | 09:51 PM
burningman's Avatar
Bow Chica Bow Wow
TMS Staff
I have the same problem and mine (2000GT) is definitly the IAC. All i have to do it tap on it and the idle comes right back up. Have someone keep the car idling and tap on it sometimes it will unstick and go back to normal. That is only a temp fix though.
My fathers SN95 had the exact same issue and once it was replaced it was good to go. I haven't done mine yet.
about a $50 part.
Here it is on the motor
you can get the part from Advanced auto or similar. Don't get it from ford it will cost you almost 3 times the price.
It's got a little electric selenoid on it and that can crap out.
Old Jan 12, 2011 | 11:07 PM
shaunrc's Avatar
Thanks for all the replies im going to clean it tomarrow cause its starting to **** me off
Old Jan 22, 2011 | 04:55 PM
did you get it running?
Old Jan 22, 2011 | 06:48 PM
Everett's Avatar
I have a 2000 gt and mine was doing that too... I gave er a seafoam treatment and no problems since
Old Jan 23, 2011 | 11:24 AM
shaunrc's Avatar
What's seafoam and where can I get it I cleaned the iac and the throttle body and it runs better but still does it here and there
Old Jan 25, 2011 | 10:09 PM
houtex's Avatar
Did you retrain the computer after? You have to do that, it 'learns' to deal with the dirty TB, so you have to unlearn it.
Old Jan 26, 2011 | 12:13 AM
shaunrc's Avatar
How the f**ck do I untrain the computer
Old Jan 26, 2011 | 01:29 AM
cntchds's Avatar
Unplug the battery and wait 30 minutes.
Old Jan 26, 2011 | 09:31 AM
shaunrc's Avatar
Thanks will do
Old Jan 26, 2011 | 06:16 PM
Everett's Avatar
Seafoam can be found at most auto parts stores....unhook a vacuum line and let the suction suck about half the bottle into the intake. Then shut off the car. Let sit about 30 mins then take it for a high revving drive. It cleans everything on the intake side including valves and combustion chambers. I do a seafoam treatment every 3rd oil change. If you put 1/3 of the can in your intake vacuum line.1/3 in the oil and 1/3 in the gas it cleans everything. It dissolves sludge in the crankcase...and I suggest doing it at night. The smokeshow that comes from the tailpipe after you do the intake is unreal. I have done back to back seafoam treatments just to see if it's the seafoam that causes the smoke or if it's carbon and crap and after the second try there was almost no smoke or tailpipe crud so it has made a believer out of me....and when I did my crankcase I changed the oil about 500 miles later and there were actual chunks of crud that came out....my car runs as good as new... And it cleans parts to like new shape
Old Jan 26, 2011 | 07:45 PM
shaunrc's Avatar
Cool thanks for the info ill try it
Old Jan 26, 2011 | 08:46 PM
Everett's Avatar
No problem...anything for a fellow mustanger...and I wouldn't suggest it if it didn't work
chorpeac
05-09 Interior and Audio Mods
22
Nov 11, 2005 08:14 PM
jgsmuzzy
1994-2004 V-6
Jul 7, 2005 09:10 PM
EleanorsMine
Off-Topic Chatter
18
May 18, 2005 01:31 PM
EleanorsMine
Apr 9, 2005 10:52 AM
