Warped rotor
Warped rotor
So I put 1" spacers in the rear of my 95 cobra...the lugs didnt let the wheel sit right on the driver rear and now it resulted in a warped rotor...just has a constant squeak. I did full brakes about 5k miles ago. Would I be safe just to change the one or do I have to change both the rears? And I'm assuming pads don't have to be changed.
Also no it shouldn't be a problem to just change one rotor, would be best to swap out the pads as well but you'll want to scuff the pad to eliminate glazing and level the surface.
9/16/15 06:44 PM
mrrooney
7/26/15 09:35 AM
