Tires!! 285/35 9in rim
Old Aug 10, 2016 | 09:30 PM
ddejesus052389's Avatar
I have an 04 GT lowered on H&R super sport springs. I have some 18x9 saleen replicas and was wondering if I could use a 285/35/18 on the front. I know the back would be fine.
Old Aug 11, 2016 | 05:40 AM
Evil_Capri's Avatar
May be a bit tight, plus not sure I'd want to run a 285 on a 9" wheel in the front. Depending on brand 285 is pushing the limit for a 9" wheel.
Old Aug 11, 2016 | 06:55 AM
So I'd be better off with 275/40/18 is what you're saying?
Old Aug 11, 2016 | 07:54 AM
Evil_Capri's Avatar
I'd run a 265/35 (or 40)/18 on an 18x9 wheel up front. I believe 275/40/18s are about an inch taller than stock, which may rub the inside, but a 275/35/18 is closer to stock ratio . . .
Old Aug 11, 2016 | 06:20 PM
285's will rub. And 275's will be tight depending on your wheel backspacing. I had the factory 17's, now have 275/35/18's. Look at some tire circumference calculators online to find the speedometer difference.
Old Aug 12, 2016 | 08:35 AM
My buddy just put 275/35/18s on his front 18x9 Saleens. No issues, but I would get the 03-04 Cobra steering stops just in case. I had 275/40/17s on my '00, on 10th Anniversary Cobra wheels, and the stock steering stops rubbed on my inner rim before I switched over to the Cobra steering stops.
shloyme
V6
12
Aug 15, 2016 12:46 PM
SN95_fambam
Aug 9, 2016 07:08 PM
Burnhaven
05-09 Exterior Modifications
16
Aug 6, 2016 09:34 AM
Coyote5-0
Aug 2, 2016 03:27 AM
