Throttle & Plenum
I have the Trickflow plenum and TB. There is a small difference, but nothing huge. I would just skip the spacer.
Put a 78 ml BBK on mine. Instant sound difference from the exhaust and love the sound of the air sucking in when you accelerate. Throttle response was improved but nothing dramatic but a good mod none the less.
Wish I would have known before I bought my 70mm.
Should be fine: http://www.allfordmustangs.com/forum...no-charts.html
with C&L plenum and 7mm tb- 266 HP and 307 ft/lb of torque
gain of 8.8 HP and 8 ft/lbs of torque
again a 70mm tb was swapped on and a 3 horse power loss was seen
A bigger throttle body will help out if you have already replaced the exhast system with hi flow cat and mufflers, but if nothing have been done you will not see any improvement in performance. The stock TB flows about 900 cfm which is good for about 450hp
Check it out, it's just what you need to help you find the right combo.
Sep 23, 2015 03:21 PM
Sep 8, 2015 10:45 AM
