Throttle & Plenum
Old May 4, 2012 | 09:29 PM
Fastang97's Avatar
Throttle & Plenum
Is switching the stock throttle body to a 70mm and new plenum a big difference?? Anyone done this?? And what about the spacer??
Old May 4, 2012 | 09:52 PM
1999Pony's Avatar
Its not going to be huge. Blue Notch did the plenum swap and liked it as far as I know.
Old May 5, 2012 | 12:08 AM
Blue Notch's Avatar
I have the Trickflow plenum and TB. There is a small difference, but nothing huge. I would just skip the spacer.
Old May 5, 2012 | 12:25 AM
Fastang97's Avatar
Ok thanks for the info :-)
Old May 15, 2012 | 09:49 PM
Crozz's Avatar
Put a 78 ml BBK on mine. Instant sound difference from the exhaust and love the sound of the air sucking in when you accelerate. Throttle response was improved but nothing dramatic but a good mod none the less.
Old May 15, 2012 | 10:18 PM
Fastang97's Avatar
Did you add a tune? Cuz I hear anything over 70mm can hurt the engine if it's not heavily modded?? Did you just do the throttle body or plenum too?
Old May 15, 2012 | 11:18 PM
Blue Notch's Avatar
Should be fine: http://www.allfordmustangs.com/forum...no-charts.html
Wish I would have known before I bought my 70mm.
Old May 15, 2012 | 11:56 PM
Fastang97's Avatar
Hmm then I guess I will go with the 75mm... Thanks for that link
Old May 16, 2012 | 05:30 AM
Knight's Avatar
Needs to be more Astony
yeah even the 7mm tb did better than the 70mm!
with C&L plenum and 7mm tb- 266 HP and 307 ft/lb of torque
gain of 8.8 HP and 8 ft/lbs of torque
again a 70mm tb was swapped on and a 3 horse power loss was seen
Old May 16, 2012 | 08:09 PM
Tommy d's Avatar
Timing adjusters set at 12 degrees ? ? Referring to article in link
Old May 22, 2012 | 01:39 PM
automan1954's Avatar
A bigger throttle body will help out if you have already replaced the exhast system with hi flow cat and mufflers, but if nothing have been done you will not see any improvement in performance. The stock TB flows about 900 cfm which is good for about 450hp
Old May 22, 2012 | 01:47 PM
Check out Muscle Mustang and Fast Fords website, they did a whole article on intakes and TB's showing what worked and what didn't. They dynoed the stock setup for a base line and every setup change. some lose power, some made power.
Check it out, it's just what you need to help you find the right combo.
Old May 22, 2012 | 02:52 PM
mdelao's Avatar
A bigger plenum and TB would decrease the MPG? In theory more air require more fuel. isn't?
Sep 23, 2015 03:21 PM
samjluck
Sep 17, 2015 10:24 PM
Sep 8, 2015 10:45 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
