So i got an interesting problem
Old Sep 26, 2011 | 11:12 PM
JDF's Avatar
JDF
So when I push my clutch and brake pedal in at the same time, my car dies. It's pretty rare but has been happening more frequently lately. The most likely solution is that re brake booster just creates enough vacuum to kill it, bit I figured I'd ask to see if anybody has a clue what's happening
Old Sep 27, 2011 | 06:01 AM
I would check for a vacum leak first. But I'm just guessing
Old Sep 27, 2011 | 06:21 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Your brake booster might be bad. How's the idle sound and at what rpm?
Old Sep 27, 2011 | 11:01 AM
Onesickstang01's Avatar
This is a gt right? That means hydro boost not vacuum. This either means that there is a problem involving power steering pump and the pressure its feeding the brake booster or you have a problem with the motor not jumping up rpms with load on the motor. Turn the AC on and see if it dies. If it does check the IAC. Also check for intake leaks, or vacuum leaks- though not as likely. Clean the MAF and do fuel filter just to be safe and general maintenance anyway
Old Sep 27, 2011 | 11:11 AM
Bear Eats King...
Bear ****s Bone
I don't know what year it is lol. 5.0 was vacuum booster right?
Old Sep 27, 2011 | 12:21 PM
Ya 5.0 was vacuum but this is under the modular forum i think
Old Sep 27, 2011 | 12:47 PM
Bear Eats King...
Bear ****s Bone
Says 94 to 04. So it could be either I guess. Lol
Old Sep 27, 2011 | 01:15 PM
JDF's Avatar
JDF
Its a 2000 GT. I just put in a new fuel filter 2 weeks ago, I'm thinking it's the IAC. I have a K&N cold air intake so it's possible. My car only has 64k miles so I'm kinda hoping it's nothing major yet
Old Sep 27, 2011 | 01:17 PM
JDF's Avatar
JDF
The idle will slowly fluctuate if it's sitting for a while. Usually from 400-900. It'll only do that if it's sitting over five minutes.
Old Sep 27, 2011 | 01:19 PM
Bear Eats King...
Bear ****s Bone
No codes? Iac will usually set one...
Old Sep 27, 2011 | 01:23 PM
JDF's Avatar
JDF
Nope no codes at all
Old Sep 28, 2011 | 07:52 AM
If it drops to 400 its an iac problem for sure
Old Sep 28, 2011 | 07:03 PM
JDF's Avatar
JDF
That's what the 3 most experienced guys (the least of which has 26 years of experience) at work were thinking. I just haven't had the the time to take a look at it
Road_Runner
Sep 2, 2024 04:46 PM
Rando
Aug 25, 2021 11:12 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
boz
Oct 1, 2015 04:47 PM
