Ruff Ride?
Old Feb 21, 2014 | 09:35 AM
hayman3347's Avatar
Talking Ruff Ride?
Question resolved...............I ended up trying a pair of those Superior Auto donut shaped rubber spacers in the springs. Raised it up about 1.5 inches and took away the jolt from road bumps. $5.99 each and about 1 hour to install. Eventually, I plan on replacing the springs and struts at the same time.
Thanks!
Last edited by hayman3347; Mar 17, 2014 at 06:39 AM. Reason: Resolved my own question
Old Feb 23, 2014 | 10:46 PM
The Mad Dooby's Avatar
Get softer springs?
Old Feb 24, 2014 | 11:08 AM
YEA SOMEONE PROBABLY PUT SOME CHEAP OR TOO BIG OF A DROP SPRINGS IN THERE. cAN YOU SEE WHAT COLOR THE SPRINGS ARE ON YOUR CAR???
Oppppps all caps
Old Feb 24, 2014 | 11:17 PM
shaunrc's Avatar
When was the last time your struts and shocks were replaced? I lowered my gt and I still have OE shocks and struts and its not pleasant that's for sure. I am due for some maybe you are as well
Old Feb 26, 2014 | 03:29 PM
hayman3347's Avatar
Well, I just bought the car a few weeks ago so I don't know how old they are. The front tires (245/r45-17) just barely clear the top of the fender wells. What do you think about changing wheel & tire sizes to like.......225/r65-16?
hayman3347's Avatar
Originally Posted by The Mad Dooby
Get softer springs?
Good answer......am considering that :-)
Old Mar 1, 2014 | 10:26 PM
Poco's Avatar
I bet they left the stock struts and shocks on the car or stock equivalent. Anytime you change the height by lower with springs its gonna change the ride big time and all that feedback(road thump) is a lack of flexibility in the spring and tire. I know, I lowered an 06'GT,07'GT 96,98 and now a 2000 Mustang. Tokiko make the best shock and strut system I've ever used for regular street use because they are adjustable for a softer ride. They cost a few bucks but you could just run stock springs for half the money and get your ride back to that softer cush your tush misses.
Old Mar 2, 2014 | 12:38 AM
Joeywhat's Avatar
I would replace the struts at least...if you don't mind stock ride height then get stock springs as well. I wouldn't change tire size, it'll throw your speedo off.
Old Sep 19, 2014 | 10:43 PM
shaunrc's Avatar
I would never sacrifice performance by changing tire size to a smaller narrow tire. You can roll the fenders or maybe get under the car and see what the guy before you did maybe cut springs or used cheap struts. And remember that with performance parts you get what you pay for don't ever go cheap on suspension
yabutt
Oct 23, 2015 01:05 PM
Sep 30, 2015 07:02 PM
samjluck
Sep 17, 2015 10:24 PM
50Cal
Sep 17, 2015 06:43 PM
robjh22
Sep 8, 2015 12:31 PM
