Randomly shuts down
Randomly shuts down
I have a 95 gt and I have changed the distributor, ignition coil and ignition control module. Now my car will randomly shut down. It usually does this after it's at operating temperature. After it shuts down, I can turn the key back to the on position and then restart it. Is my icm bad even though it's new?
Was it shutting down before replacing those components? If not, and if you still have the old parts, try swapping out one at a time and see if the issue goes away. That way you'll know if one of the new parts is bad. Coil or ICM would be my guess - I don't see how the distributor could cause this.
Rando
8/25/21 11:12 AM
DerekShiekhi
9/30/15 06:59 AM
