Power Window not working
Old Mar 14, 2007 | 08:03 AM
Robbieg's Avatar
I am trying to pinpoint a power window problem with a 2003 Mach 1. The problem is intermittent, sometimes the drivers side window will not go down, you just hear a click. It has never failed to go up, just down. When it was under warranty I took it in for this and the dealer replaced the window motor but I was never convinced it was the problem. Now it has been about 1 year and it has started again, sometimes it will work, sometimes it wont. I don't know if its just a coincidence or just my imagination but the problem always seems to be in the afternoon when its hot out and not in the morning when its cool, I don't know if that has anything to do with it or not. Anyone experienced this problem or have any suggestions. Thanks for any help.
Old Mar 28, 2007 | 08:33 AM
Miserable's Avatar
I seem to be having the same exact issue with my 03 GT. Happened once before and just happened yesterday afternoon when it was hot. This morning, it worked fine.
Old Mar 28, 2007 | 08:55 AM
GottaHaveIt's Avatar
Any chance in between times that you would have had the battery dissconnected ? maybe like eith the 05's and up you can calibrate it again, it should be in the manule if so ? Good Luck
Old Mar 28, 2007 | 09:48 AM
Miserable's Avatar
Haven't had my battery disconnected since last summer. I used to have a grand prix that used to do this to but at least it had 4 doors so I could still get some air into the driver's side.
Kefka21
Aug 28, 2015 03:11 PM
MRGTX
Aug 14, 2015 11:33 AM
lakersfreak
Aug 12, 2015 01:52 PM
Earlsays
Jul 14, 2015 05:25 AM
Kev006
Jul 8, 2015 05:29 AM
