PI swap or engine Swap?
Old 12/21/13 | 03:38 PM
97GT03SVT's Avatar
Hey everyone I'd just like some honest opinions and feedback on a potential upgrade to my car. I own a bone stock 1997 GT with 90k the car is very clean and reliable. I'm looking to sell it to a friend when I'm ready to buy a 2005-09 GT this spring. This car will almost certainly be modded once it is sold.
This person has no mechanical skill should he buy PI heads/cams/intake and pay someone to install them or should he just buy a complete 2003 GT motor with 66k for $1500 and have installed?
If the engine swap is easy enough to do it would probably be more reliable that messing with the current tired engine.
Thoughts? Opinions?
Old 12/21/13 | 04:08 PM
AlsCobra's Avatar
A Man Just Needs Some....
I really don't know the difference of a 97 and 03 engine. Did the motors really change enough to justify the swap? The best mod I've seen for any of those is just a supercharger kit. They respond well to them and you shouldn't have to touch the motor.
Old 12/22/13 | 09:35 AM
97GT03SVT's Avatar
The 1999-04 2V 4.6 had improved heads,cams and intake. This gives the car 45hp and 20tq over the 1996-98. This comes into play with modifications too. A supercharged PI engine has much more potential than a non PI. In a way the feel is like the difference between a 1999-04 to a 2005-09.
Because the 1996-98 cars make higher compression that actually produce more hp than a 1999-04 car when they have PI heads/cams/intake. I know someone who made 280hp with this swap and a cai and tune. I heard once the swap is made you have to use premium fuel. With swapping to a newer motor you don't have to modify anything and can use regular fuel and personally I feel it will likely be more reliable. I just wish I knew the labor between both choices
Old 12/22/13 | 10:17 AM
Does he have access to a cherry picker? If not, and he's going to pay someone to do the engine swap, you could almost double that $1500 just in labor. I'd do the PI swap, as long as you do a compression test and everything is good. 90k is nothing for these engines - it's just getting broken in!
Old 12/23/13 | 04:50 PM
Krohn's Avatar
I wonder... are there any other engines worth buying that aren't too much more, if any? Like an '01 cobra motor?
Old 12/23/13 | 08:24 PM
1999Pony's Avatar
PI swap. Labor would probably be more on the engine swap with less return.
Old 1/4/14 | 07:21 PM
97GT03SVT's Avatar
This car has about 90k on the odometer, do you think it should be rebuilt with the PI swap? Also how much would all the parts cost?
Old 1/6/14 | 03:17 AM
bob's Avatar
bob
Tell him to go a price each job. PI swap or motor install then weigh the costs.
Although if I were going for a motor swap, maybe it would be better to just save his pennies then build a motor and drop it in.
Old 1/8/14 | 04:25 PM
97GT03SVT's Avatar
update : a Guy on Craigslist has a set of heads and intake complete with cans and valve covers for $450. what should I look for to see if everything is legit also. what else would be needed for the swap? the heads and intake are from a 2000 GT
Road_Runner
9/2/24 05:46 PM
trackpack13gt
10/2/15 09:20 PM
Ray11
9/25/15 01:43 PM
Quick Reply: PI swap or engine Swap?
