Mustang 2003 V8
Old Nov 6, 2010 | 02:47 PM
MAHOOZI's Avatar
Mustang 2003 V8
I have the Ford Mustang 2003 V8 4.6 I want to force the car to lift +500 HP How I do
My car Stock
Please help
I'm not from America
Old Nov 7, 2010 | 02:57 AM
cntchds's Avatar
Looks like Middle East somewhere?
Welcome!
I would say that the easiest way to 500 hp would be through forced induction, and even then you are going to find a lot of headaches getting that much power. What is the main purpose of the car going to be?
Old Nov 7, 2010 | 03:41 AM
MAHOOZI's Avatar
Welcome!
yes ..
Thank you
But what do you propose to do for the development of the car ..
Do you replace the engine of 4.6 to 5.6??
The purpose of the is to show and race some time
Old Nov 9, 2010 | 02:01 AM
MAHOOZI's Avatar
any bady can help me,,?
Old Nov 9, 2010 | 04:29 AM
Evil_Capri's Avatar
Hmmm . . .
I would find out what parts are most accessible and are you planning on working on the car yourself or taking it to a shop?
If you are wanting more HP/TQ are you also prepared to upgrade other drivetrain components? (Clutch, Transmission, etc.)
Perhaps installing a supercharger or turbocharger would be the easiest way to go. You may not hit your 500hp goal, but what's in a number anyway?!
If it were me . . . . I might obtain a Hellion Turbo Kit.
http://www.hellionpowersystems.com/i...article&id=134
Old Nov 9, 2010 | 02:12 PM
MAHOOZI's Avatar
Originally Posted by Evil_Capri
Hmmm . . .
Thank you
If you change the engine from 4.6 to 5.6
And put supercharger Can I access to 500 hp
And will change a few things if necessary
Old Nov 9, 2010 | 02:19 PM
Red Jay's Avatar
Originally Posted by MAHOOZI
Thank you
you dont need to increase the displacement. 500hp is obtainable with just 4.6L or 281 cubic inches. Roush has a supercharged 4.6L Mustang that produces 540hp at the crank. i dont know whats all done to the engine besides the TVS supercharger, but this isnt the same 4.6L as yours. if you do decide to go the forced induction route then it might be better to build the engine from the block on up with better parts (rods, pistons, injectors, ect.).
Old Nov 10, 2010 | 01:53 PM
cntchds's Avatar
For whatever reason people seem much more comfortable pushing extreme amounts of power with turbos more than with superchargers. I don't really know why, but that seems to be what their kits are geared for. I would say that if you just want to hit the 500hp mark then that is probably your ticket. Get all of the supporting mods done first so your drivetrain doesn't implode under the boost, and then have at it.
And like some people have said, the 5.4 is not a necessity to get to the magical 500, but if you are going for the wow factor, a Navigator DOHC 5.4 does look pretty cool under the hood...
Old Nov 10, 2010 | 07:25 PM
Knight's Avatar
Needs to be more Astony
easiest way is to throw on any supercharger you can get and then spray a 150 shot of nitrous. Thats the easiest way I could think of other then just spraying a 250hp shot of nitrous.
Old Dec 14, 2010 | 08:19 AM
MAHOOZI's Avatar
In the states can not use nitrous
This means if you used your access to prison
Old Dec 14, 2010 | 08:28 AM
MAHOOZI's Avatar
Look at this engine
http://www.fordracingparts.com/parts...KeyField=10355
What do you say it
Old Dec 20, 2010 | 01:21 PM
oifdoc's Avatar
dont worry about getting another motor! the one you have is good enough. there are alot of ways to go about this! it will all depend on your budget though. so get a figure together that you are able to spend then add another 1k on to it because some things will come up!
also where you are located has a big factor in what parts are available and keep in mind your shipping rates.
i spent time overseas and shipping can be costly!
and where you are will pay a crucial part in the motor as in the climate (heat and the elivation) keep all that in mind on your build. might want to upgrade your cooling system!
Old Dec 22, 2010 | 02:57 PM
Everett's Avatar
F/I is the only way to meet your goals.unless you put massive cubes under the hood.
Old Dec 24, 2010 | 07:15 PM
MAHOOZI's Avatar
I know it all
If you have this car and you have the capacity to do what will be developed to a large extent,
And what do you advise me to do and I have the about $ 14,000
And you did not answer me to my question Can I install this engine and what are the consequences
If you want to get 650 hp will do what
Old Jan 1, 2011 | 10:40 AM
Hawaii 5.0's Avatar
I think the roush engine is the same dohc mill thats in the mach 1 and cobras. Higher revline, quicker revs, and several other things. With the way the engine is built u can mount a supercharger on top and most of thos superchargers like the kenne-bell, eaton, etc. Can easily achieve that 500hp benchmark. The vortech supers (centrifugal style) actually kinda look like a turbo and another main difference is they build upnpower as they move, as in they faster the car goes the stronger that super gets, or something like that. My buddy has a vortech in his 03 gt, along with k&n cold air, borla stinger s type cat-backs, MAC long tube headers, 75mm throttle body and plenum, toming adjuster, underdrivepulleys, and an upgraded clutch and flywheel. Oh and 3.73 gears. We did a dyno test and hes runnin 575 horses and 560 lb ft tourqe. Pain in the *** build process but the results are amazing
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
dohc97
Jul 19, 2015 07:29 PM
Jul 17, 2015 05:40 PM
