Misfire after tune up
Old Oct 13, 2013 | 04:53 PM
2_CW_2's Avatar
Car still misfiring after I've replaced spark plugs, coil packs, fuel filter and mass air flow sensor. Local auto zone ran a diagnosis on it codes came back for O2 sensor in bank 1 but I have catless exhaust the O2 sensor are plugged in should I buy new O2 sensors???? Open to all suggestions
Old Oct 14, 2013 | 12:06 PM
td01gt's Avatar
What are the actual codes that are showing up?the misfires should be showing a code.
Old Oct 14, 2013 | 01:02 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
I would pull the new plugs and check for cracks or damage.
Old Oct 14, 2013 | 04:02 PM
2_CW_2's Avatar
The only code that it's showing is for my O2 sensors
Old Oct 14, 2013 | 04:10 PM
2_CW_2's Avatar
Ok I'll try that
Old Oct 14, 2013 | 10:48 PM
shaunrc's Avatar
Seems like the only thing you haven't replaced that could also cause a miss is fuel injectors. Since you have replaced your coil packs and plugs turn your car on and unplug fuel injectors. Everyone you unplug should make the miss much worse so.... whichever one doesn't effect this miss fire is the bad injector
Old Oct 14, 2013 | 10:51 PM
shaunrc's Avatar
And don't buy new o2 sensors cause the light is going to just come back on. You need MIL delete connections. Or just deal with the check engine light. I do its kind of annoying but I know its the rear o2
Old Oct 15, 2013 | 10:51 AM
2_CW_2's Avatar
Thanks bro im gonna try that out today!!! Ya the check engine light came on soon as I deleted my cats.
Old Oct 15, 2013 | 05:05 PM
LivinTheStangLife's Avatar
Yep MIL eliminators to the 2 blue back o2 sensors should take care of it if you removed your cats
Old Oct 22, 2013 | 06:51 PM
2_CW_2's Avatar
I'm tryna see what's causing the misfire
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
