1995 Mustang GT Overheating Help !!
Old Oct 21, 2013 | 10:07 PM
shariphe sn95's Avatar
Okay I have a 1995 mustang gt and I'm having a overheating problem.
Parts that needs repairing
Radiator Fan does not turn on
A/C does not come out my front vents blows warm air
Need a new IAC Valve
I checked the thermostat and it opens up so that can't be the problem Im guessing
When driving low speeds my engine heats up between the A&L before going down "Normal", after about 2 more miles it heats up again to the point I have to pull over
There is no white smoke or milky brown fluids coming from the engine or radiator
If anyone is having this problem please reply
Old Oct 22, 2013 | 06:26 AM
sounds like there's a bigo air bubble in there. Have you ran/idled it with the rad cap off with the front end at a slight incline? Ran it for like 20 minutes until its good and warm and you can see the fluid flowing in the radiator
Old Oct 22, 2013 | 02:34 PM
No I have not yet I will later today though, after I do that what should I do ?
Old Oct 22, 2013 | 06:02 PM
hopefully you will see that it needs more anitfreeze and water mix.
Old Oct 22, 2013 | 07:28 PM
Okay ill post what happens
mark0006
Sep 8, 2023 09:46 AM
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
dohc97
Jul 19, 2015 07:29 PM
Jul 17, 2015 05:40 PM
