Mark 8 shortblock.
Old Jan 4, 2012 | 10:52 PM
Torrbo916's Avatar
Mark 8 shortblock.
So I came acrossed a deal on a bottom end from a 98 mark8 with 70k on it($100). It's aluminum. Is this worth the time and effort to tear down and re assemble for my gt. What are the pros and cons. Any common issues with the aluminum block. Would I be able to use termi heads and an 03 timing set on this. Is everything pretty solid on these as well. please help.
Old Jan 5, 2012 | 04:53 AM
32vNomad's Avatar
Well that block is known as the teskid block made in italy. The block has been proven 1500+ hp. Yes its worth it. But there are some things to know the crank though good for 500+ hp is a 6 bolt crank if on a budget this is fine to keep. Means you won't need to change flywheel. Rods and pistons are same material as the GT. I opted for forged rods and pistons on my build, along with good bearing and seals. I would hunt down mach 1 parts to make a swap easier. Timing cover, throttle cable and harness. But the gt harness can be used for 4v heads.
Old Jan 5, 2012 | 11:36 AM
32vNomad's Avatar
GTPETE
Oct 12, 2015 02:20 PM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
Last1
Aug 21, 2015 10:53 AM
