MACH 1 SHAKER HOOD
Old Apr 5, 2005 | 03:12 PM
larlar's Avatar
:scratch: TRYING TO FIND OUT IF A MACH 1 SHAKER HOOD WILL FIT MY GT DONT KNOW HOW THE SCOOP MOUNTS ANYBODY KNOW THANKS...LARLAR
Old Apr 5, 2005 | 05:14 PM
dfhurleydude182's Avatar
Next time try to make your post a little more clear... I am not sure if an actual mach 1 shaker hood scoop will mount on to your 2v, but I know that companies such as Classic Designs Inc. make kits to fit the 2v's.
Old Apr 5, 2005 | 07:33 PM
larlar's Avatar
thats what i was wondering about how the scoope mounted to the engine ill check on that kit thanks. ill try to be more clear next time..larlar
Old Apr 6, 2005 | 09:47 AM
TRMach1's Avatar
I could be wrong, but I do not believe that the CDC kit will work with a factory Mach 1 hood, shaker scoop, and a 2V motor. I think it only works with their shaker system, which requires cutting out the stock GT hood. As far as I know, Kar Kraft is the only vendor that offers a kit that allows for the use of a factory Mach 1 shaker scoop and hood mounted to a GT 2V motor. You may want to check this link out. http://www.karkraft.com/new_page_7.htm
Old Apr 6, 2005 | 11:29 AM
JohnMarshall's Avatar
I used the Kar Kraft kit. I already had a factory hood and shaker. I was able to buy just the brackets from Kar Kraft. It bolted up in minutes. Good luck.
Old Apr 6, 2005 | 12:01 PM
1999 Black 35th GT's Avatar
This may be a little off topic but how much horsepower and torque would you gain on a 2v with the shaker? Are there any sites our dyno tests for it?
Old Apr 6, 2005 | 12:06 PM
forddude1416's Avatar
If I remember correctly, which is rarely, it doesn't do that much. Maybe 1-3 ponies tops.
Old Apr 6, 2005 | 12:45 PM
Thats it For almost eight hundred bucks. Doesn't seem worth the money to me. You could go a more aggressive exhaust, or performance cams, or emaybe better heads (if you find a good price) for $800. I thought it would add 20 to 25 hp.
On the other hand the shaker system is the coolest looking upgrade for your car.
Isn't there a system out there though that will make the stock hoodscoop funtional? :scratch: I thought I remebered reading something about that.
Old Apr 6, 2005 | 03:16 PM
conv_stang's Avatar
yeah, it doesnt add much that you can actually judge. it helps at high speed. which you cant measure on the dyno. but it definitely adds to the looks dept.
Old Apr 6, 2005 | 05:42 PM
charles's Avatar
depends how fast your going you probaly need a NASA formula to figure out the hp at certain speeds
Old Apr 7, 2005 | 09:06 AM
E=mc2
May 3, 2026 05:42 AM
duppycat
Feb 16, 2019 08:36 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
