kenne bell
ok I had one on an 89 5.0 and yes they do make them for the 94-95, on your stock internals 8 PSI...but if you fealt an 8 psi blower on your car, you'd be amazed...but be prepared, cause your gonna break stuff.
I had a 2.2 Liter blowzilla on my 5.0 and I ran 8 psi for a while with full forged internals, and then I went to 10 psi, make sure you have the fuel system. your low end torque will be amazing....the boost is full about 2000 RPM (truthfully) and stays that way all the way to 6000 RPM...which if your spinning your 5.0 more then that, your just hurting yourself....open up your exhaust real good, or you'll kick yourself. patience and a little bit of a budget when you blow things, I blew a tranny (stock AOD) and I put in a TCI street fighter, no problems after that. blew stock HG's, went with better cometic headgaskets and no problems til I split the block (tried 13 psi....)
yeah i saw where i can get a 2.2 blowzilla.. 8psi is the most i can go, before needing forged internals. where is a good place to get a good deal on one? some guys tell me to go procharger, but i heard KB was instant power and it wouldnt fill my engine bay.
go DIRECTLY through kenne bell...do not go through anyone else.....it is instant and it is nice looking, no battery relocation or intercoolers to route....call KB and give them your money.....sometimes they are hard to get through to....be patient.
http://forums.bradbarnett.net/showthread.php?t=67150
In about two week I'll have a KB installed in my 4.6 3V. It will be intercooled and pushing 12 psi on stock internals. This set up is midrange the Blower can go as high as 24 psi but that's too crazy even for me.
Check out Kenne's site for more info:
http://www.kennebell.net/
Bill
redrock35
05-09 Exterior Modifications
7/31/16 09:50 PM
Detroit Steel
2007-2009 Shelby GT500
8/17/15 03:29 PM
