Idle problem
Old Feb 7, 2005 | 06:14 AM
JRTMustang's Avatar
I have a 2001 manual GT ... Since early december, it occured about 8-10 times: I start the engine but it will not idle. I have to hold the gaz pedal otherwise the engine dies. This condition may last for a few minutes or up to an hour. Suddenly, I feel like something is "kicking in".. the gaz pedal feels different and the idle problem dissapear .. . anybody have a clue ???
Old Feb 7, 2005 | 09:18 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
IAC Valve. The Idle Air Control Valve ford has used on 4.6's is notorious for getting dirty and causing problems with initial startup. It works great after its warmed up a bit.
You can take it off and clean it, but thats only going to fix it short term. Go to ford and get a new one when you have the money. That should fix it. (although i've seen a new one go bad in a few months )
Old Feb 7, 2005 | 09:31 AM
UA2k1GT's Avatar
its a very common problem with the 4.6 Replace it, supposedly a new one from Ford is supposed to be better designed than the stock one. Also fairly cheap fix.
Old Feb 7, 2005 | 11:36 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
who you calling stupid?
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Airborne42
Sep 24, 2015 11:01 AM
