I need your input!
I need your input!
hey everyone
i have an 01 gt and im looking to start upgrading it in a couple months
moneys not too much of an issue with me
im thinking about installing a magnaflow exhaust system with a high flow intake
sometime after that i would like to supercharge it
if i s/c it then would i need a new block?
after that im not sure where to look
in the end im looking to have my car up to around 450-500 hp
any suggestions on what i should do?
thanks!
thanks!
Well on a 2v you can supercharge your car and get about 400rwhp safley without causing and potential premature failure. but if you go over 450rwhp you are going to want to start upgrading things like rods,pistons,cam. as for exaust. check out youtube. they have every kinda of video over there. WWW.lethalperformance.com they have a great selection of superchargers for our cars.
thought you might like this.
http://www.mustangforums.com/m_2189116/tm.htm
hey thanks
so what would cams, pistons, etc put me at money wise and hp wise?
and also would a kenne bell Big Bore 2.1L be a good choice for a s/c?
thanks for all the help everyone
Cams, pistons and rods. your looking at about $2250 + installation. hp wise it sucks for us because we have 2v heads and they dont flow very well. so probably 280 RWHP thats with a good dyno tune.
Yes it would, thats AFTER you get Better internals. you can get the kenne bell now and only run 5-8 psi to not kill the motor and then get the pistons etc.
it all comes down to how much you want to spend, if you want to spend more than 10k, you should've gotten a mach 1 or cobra.
hey everyone
thanks!
thanks!
Suggested mods in order of importance:
Aftermarket shifter....I suggest Steeda Tri-ax
Full length subframe connectors (a must have)
Cobra/Bullit Brakes and stainless brake lines
Rear Upper and Lower control arms...I like Steeda's (Aluminum..lightweight)
Lowering springs...I like Ford Racing "C" springs
If you lower your car you have to have Caster/Camber Plates, Offset rack bushings,Steeda Bumpsteer kit and Steeda X2 ball joints. Don't learn the hard way like me and ruin a good set of tires because I didn't do it right from the beginning.
Front strut tower brace
Aluminum driveshaft
Now you are ready for more power, the 4.6 loves a Supercharger.
well johnny 5(short cicut reference)...i would definately look into exhaust and intake first, easy gains there, but you may want to go with lightwieght driveshaft, shifter, better brakes, make a close inspection of any other driveline parts that may need repairs or minor upgrades, then look into power adders, really it all comes down to how much time you want to invest into a car
johnny 5 always wanted "input" for those who are lost...im stupid..lol
also
if i had a s95.. i would love this http://www.jmsproductsinc.com/
also
Just get the Hellion kit and pro chamber and mufflers thats what i would do if i had the cash, it would be fast and streetable and there are lots of s/c stangs but few turbo ones i was going to do it on my 03 but i had finacial issues
9/8/15 10:45 AM
