How much hp will I gain?
Old Jan 11, 2012 | 11:19 AM
Falco_03GT's Avatar
How much hp at the wheels will i gain with my JLT cai, BBK 78mm throttle intake and SCT Tuner with custom tunes?
Old Jan 11, 2012 | 11:25 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
If your lucky I'd say 20
Old Jan 11, 2012 | 11:41 AM
1999Pony's Avatar
If your very lucky. The tuner will give you the most gains and is dependent on the type of tune.
Old Jan 11, 2012 | 05:12 PM
skunk21's Avatar
people put too much faith in the cai.
Old Jan 11, 2012 | 05:18 PM
AlsCobra's Avatar
A Man Just Needs Some....
Yep. It worked better in the fox's with the MAF but the newer computer systems can't be just tricked anymore. They don't do anything without a tune now.
Old Jan 11, 2012 | 05:49 PM
skunk21's Avatar
True OBD1 cars where much easier to mod to a point but even then a cai didn't do much of anything. In stock form bumping the timing and gears woke them up more.
Old Jan 11, 2012 | 05:51 PM
AlsCobra's Avatar
You make me want another notch 5.0. Wasn't fast but really a fun car.
Old Jan 11, 2012 | 05:55 PM
skunk21's Avatar
LOL. they are fun, light and can be nasty .
Old Jan 11, 2012 | 05:57 PM
White94GT's Avatar
American muscle claims 20hp-30trq on a stock motor but every car is different !
Old Jan 12, 2012 | 08:22 AM
1999Pony's Avatar
Yea, I wouldn't count on that.
Old Jan 12, 2012 | 12:48 PM
Pete07GT's Avatar
Nominal horsepower gains until you build the motor up enough to change the compression ratios and (or) go forced induction. Wouldn't a throttle body be the very last thing you want to put in? Stock internals wouldnt benefit a great deal from a bigger TB. Put your money into nominal gains on the RAM AIR INTAKE (people calling them cold air is beyond redonkulous at this point) and put in suspension components as you keep modifying the motor!!!
Old Jan 12, 2012 | 05:04 PM
White94GT's Avatar
Yea me either !! You really don't know what you have till you dyno the car with all the parts on!!!
Old Jan 13, 2012 | 10:51 AM
skunk21's Avatar
you don't have to change the compression ratio although I will admit I'm not all that savy on the mod motors but I can build a pushrod motor w/o changing the compression and get close to 300rwhp N/A w/o much effort.
Old Jan 13, 2012 | 10:56 AM
Bear Eats King...
Bear ****s Bone
you don't have to change the compression ration although I will admit I'm not all that savy on the mod motors but I can build a pushrod motor w/o changing the compression and get close to 300rwhp N/A w/o much effort.
Pete don't know much
Old Jan 13, 2012 | 11:01 AM
skunk21's Avatar
Oh okay
Old Jan 16, 2012 | 12:36 PM
Falco_03GT's Avatar
What do you guys suggest I do? She's pretty much stock and I know a guy who's a ford master mechanic so I'm pretty much open for anything.
Old Jan 16, 2012 | 02:20 PM
skunk21's Avatar
depends on how much you want to dig into the motor like heads, cams , etc.
I'll go with basic bang for the buck 1st..
GEARS, they don't add hp but they are so over looked. you want your car to have off the line grunt and pull much better than it is now then gears. I'm thinking you have 3.27s so 3.73s will give you a little more bump but 4.10 will give it a nice feel.
Drop in K&N filter into your stock box / remove silencer
get a better flowing mid pipe and cat back
option: long tubes ( more hp ( 10-15 easy with a good mid pipe and torque over shorties) don't bother with shorties at that point just go mid to cat back with stock headers
tune
(but if you tear into the motor and add better flowing heads, cams, larger injectors, fuel pump, etc go to a shop for tune )
Old Jan 16, 2012 | 05:24 PM
Falco_03GT's Avatar
Maybe looking for a big hp gain like supercharging it. Maybe something like that from americanmuscle.com ?
Old Jan 16, 2012 | 05:54 PM
skunk21's Avatar
SC and gears would do it but get a good tune at a shop you will need more than just the SC.
amercian muscle or
http://www.latemodelrestoration.com/Mustang
or
http://www.summitracing.com/
Old Jan 22, 2012 | 03:52 PM
stork68's Avatar
I have a 04 GT with 78mm throttle body, CAI, short tube headers, Magnaflow X-pipe & catback exhaust, Comp Cams stage II cams, and typhoon intake. Had it dyno tuned and got 267 rwhp and 280 rwtq. My base line before the dyno tune was 228 rwhp. If your going to invest alot in mods have it dyno tuned. I gained nearly 40 rwhp. I'm putting in a Procharger kit this spring, hoping to get 350-400 rwhp.
