How to change rear gear oil on Mach 1
Old Sep 3, 2011 | 03:46 PM
traffic142's Avatar
I am changing my daughter's 03 Mach 1 rear gear oil. I need to know if there are anything weird? Also any one know the torq on the bolts?
THanks
Old Sep 3, 2011 | 07:57 PM
JDF's Avatar
JDF
Loosen all the bolts, and then remove the bottom half of them. Grab a pry bar or screwdriver and shove it up into the bottom. It will smell horrible
Old Sep 3, 2011 | 07:58 PM
JDF's Avatar
JDF
Sorry, I can't help on the torque rating, the guy that did it for me wailed on it with an impact (that's not my suggestion at all, he has 30 years of experience)
Old Sep 4, 2011 | 04:03 PM
southsidexers's Avatar
Hey I just did my Mach 1 last week as well as replaced my pinion seal. It's very simple they're all 13mm bolts. Just make sure you remove the old gasket on the cover and spread a new thin bead of gray rtv around the cover. And just get the bolts tight and they'll be fine. The exact torque isn't super important in this application.
Old Sep 4, 2011 | 09:22 PM
sinisterbullitt's Avatar
Nope just remember as soon as those bottoms are lose nasty gear oil gushes out. Razor blade the factory seal off make sure you clean the magnet in the cover. It comes off. Spray gears real well with brake clean..etc...clean inside of cover. Like they said above a nice bead of rtv. And make sure you get manufacturer recommended fluid.
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
EaterofWorlds
Nov 23, 2015 08:51 PM
mrp5150
Aug 23, 2015 06:29 AM
