hood scoop
I may get a 99-00 GT...and they dont have the hood scoops like the 01+ and i require 1...how much does it usually run to get 1 of those scoops? i think i remember seeing them somewhere u could purchase them...any thoughts? thanks
www.classicdesignconcepts.com
sells a good reproduction. I'm thinking of getting one myself. Also check out their other items: the mach 1 chin spoiler should be mandatory!
hmmm not that bad actually...only $145.....anyone actually use this? http://www.classicdesignconcepts.com/catal...isplay/545.html
i hear CDC is pretty good...if only Cervini had 1, id buy it from them probably lol....also anyone know off the top of their how much it would cost to paint such an item?
Originally posted by TennesseeMustangManiac@August 29, 2004, 12:51 PM
Get the Mach 1 Shaker functional hood scoop! $780 but its so sweet.
Find a 1999 "Limited" GT and it came with scoops stock. There are always a couple for sale at www.mustang35th.com
Scoop should run $100ish. You could probably get one off ebay. I got a whole hood off ebay for $200 a year ago. The scoop is pretty easy to install in case you don't buy a whole hood. The issue I ran into was getting it painted to match. Turned out it was easier and cheaper to remove the scoop from the other hood, drill holes in my car's hood, and attach the scoop onto my v6 hood. (they are identical hoods) I got my scoop painted at the local Maaco for $40. Not a bad match, just check on alternative paint colors. Apparently some Mustang colors are hard for the factory to consistently create so there are alternative versions of them. The body shop rep can explain better than I can. All in all, it is a very nice addition to your car and really looks nice when behind the wheel. Hope this helps.
Originally posted by 35thGT+September 8, 2004, 2:17 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (35thGT @ September 8, 2004, 2:17 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TennesseeMustangManiac@August 30, 2004, 10:28 PM
35th GT, your avatar is a little disturbing.
Its my nickname and my screen name at StangNet. [/b][/quote]
Hahah, I thought I recognized that avatar from somewhere.
Howdy Jason!
http://forums.stangnet.com/member.ph...astposter&f=83
