Freon or Coolant?!
Old Oct 13, 2014 | 08:42 PM
benjyc32's Avatar
Freon or Coolant?!
So today I was driving my 2001 GT I just picked up over the weekend and I turned on my A/C and noticed a nice hiss sound occasionally when it is running. Coincidentally I noticed that I had a green fluid near my intake manifold on my passenger side near the back of my engine near the high and low a/c ports (the high and low ports have condensation on them). That green fluid could be oil/freon from the a/c and it is genuinely leaking and nothing else, OR I have a intake manifold leak AND I have a a/c leak.
Thoughts?!
I have never seen freon before and google isn't much help…
Any help would be great as I have had a bad intake manifold before with these. Lucky this car already has a Professional Products Satin Typhoon Intake Manifold (from the looks of it) so hopefully I'm correct and it is just a a/c leak.
The coolant level seemed to be slightly low when I purchased it, but I didn't notice any leaks and never used the a/c in the test drive to see if it happened then. I drove it about 500 miles since I got it and this is the first time I've used the a/c for more than a minute or two. The coolant light has not come on since I got it and the car never runs hot and my scanning software confirms that it doesn't run hot.
Thanks,
-Ben
Last edited by benjyc32; Oct 13, 2014 at 08:44 PM. Reason: additional text was added that I felt was important information for diagnosis
Old Oct 13, 2014 | 08:46 PM
They make refrigerant with a green dye in it so you can spot a leak. But it doesn't come like that from the factory.
Question is are you the only owner and has anyone ever serviced the AC before. If you can say definitely not then it's a good chance it's not refrigerant dye.
Also from using the product it does not make a mess. Sometimes it can be very hard to see. It would have to be a large leak to make much of a mess outside the size of a dime or so. It would be oily though as it is a lubricant added into the refrigerant or freon if you will.
Old Oct 13, 2014 | 09:00 PM
benjyc32's Avatar
It is defiantly a noticeable hiss when I have the a/c on even at 70-80mph with a x pipe and magnapacks for my exhaust. It feels like it is slamming my a/c clutch when it happens too. And no I'm not the only owner, like I said I just picked it up this past weekend and the car fax said its had 5 owners since its original purchase in 2001. I'd love to say its just antifreeze and since the car has been all over the east coast with owners I'm sure the a/c has been either replaced or recharged.
Old Oct 14, 2014 | 12:58 PM
benjyc32's Avatar
It turns out that the nipple running from the heater core return line into my intake Manifold had a crack running the length of the nipple and thus causing it to leak. A quick run to the parts store and $4.36 later for the replacement and I was back on the road in 10 minutes
unnoticedtrails
Jul 17, 2017 11:10 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
NC14GT
Aug 2, 2015 07:27 AM
Crazy Mustang Man
Aug 27, 2006 08:07 AM
